  1. First of all am Sorry, if its wrong section or if am breaking rules
    ____________________________________
    Its about "bit rate" and "Maximum bit rate" of Video
    See Most of my Videos have "Bit rate" but Some of have "Maximum bit rate"
    And Surprisingly my One Video is 720 X 400 Bit rate 486 Kbps But Maximum bit rate : 4 595 Kbps
    and That Video Has better quality than my other Video even better than my 600 bit rate one Too.
    I tried some Converter to compress my video, But Non's reslut have "Maximum bit Rate"
    Here is Below File INfo of Video -- http://pastebin.com/9MXRCmti
    or check below attachment
    help me abt it !~!~!
    It has probably a Variable Bit Rate.
    How do you convert now?
    You can convert try to h264 video with variable bitrate using 2-pass encoding or constant quality/rate factor. Use for example vidcoder and configure the encoding settings under the settings and the video tab.
  3. @Baldrick -
    Please could show me a sample Here below is 2 mb file,
    http://www.putlocker.com/file/74245FEFB24A6D28
    Ur Out Put Video File must Have "Maximum Bit Rate"
    http://screensnapr.com/v/1UPo3v.jpg
    am using Meida info to View above Info
  4. The values that MediaInfo reports can be wrong -- it mostly just reports the values in the header. Use Bitrate Viewer instead. It will parse the video and report more accurate information.
    You can't use bitrate to compare the quality of different videos. Different codecs, different settings, and even different videos have different bitrate requirements.
    A variable bitrate file will have more than the average bitrate in some shots, less than the average in others.
