I would assume that converting DivX video of 720x576 resolution would produce better quality VCD then converting a DivX video of 640x480. I would like a second oppinion on this.
Thanx in advance
(Once again, Rev. Jake speaking strictly from his own experience)
I can detect practically no difference, seeing as both files have dimensions that you're going to knock down to VCD resolution. When it's all going to the same size, I can't visually tell a difference.
*Upsizing* video, though---now *there's* where you can tell a quality difference. -
Take a great source (such as a DVD), then rip/divx encode a chapter at 720x576, then rip/encode the same chapter at 640x480, same settings (other than resolution).
Convert one to VCD, and then the other. Compare the results. This way you will know how it looks to YOU, as opposed to how it looks to others.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Advice on Conversion software
By tcory in forum Video ConversionReplies: 7Last Post: 22nd Sep 2011, 23:19 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 02:17 -
Need advice on BR conversion
By tech3475 in forum Blu-ray RippingReplies: 3Last Post: 30th Apr 2010, 14:57 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28
