  1. I don't know when this happened but I am unable to activate removedirtMC script
    as you see on the picture I even tried to put it (the script it self) in my script still get error and it seems continues to brag something about syswow64 folder and some ntdll.dll file but i searched with everything and it is there I don't have clue what it is.
    Before jumping about it i have all the filters necessary in the plugins folder all avsi script's that i use i even tried to delete the plugin folder and call it from another folder where all files are and still the same deal.
    It is windows 7 64x by the way avisynth 2.6 MT 32
    Any thoughts?
    Thanks guys
  2. I always get that with values over 14 (I see 50 in your screen shot).
  3. I always get that with values over 14 (I see 50 in your screen shot).
    I uninstalled avisynth and avspmod and xvid4psp with uninstaller then delete left overs on hard disk and registry and renstalled it again now it works and on 50 60 jagabo
    I don't know why you have only the problem after 14 but maybe re installation of avisynth might help you.
    another problem is that Removedirtmc or descratch or despot and similar don't get rid of the white thick drop out i will post samples soon
  4. Originally Posted by mammo1789 View Post
    I'm sure it has something to do with the version of each of the filters and AviSynth. Since I don't use RemoveDirtMC() I think I'll leave it alone for now. Thanks for the info though.
  5. I'm sure it has something to do with the version of each of the filters and AviSynth. Since I don't use RemoveDirtMC() I think I'll leave it alone for now. Thanks for the info though.
    I think so also there are many versions of the same plugins that it is very difficult to make some scripts work or work properly ( my biggest complaint always about avisynth stability and compatibility sometimes ).
    By the way i made the drop outs less visible with devcr ( it also had problems with my previous installation) and now after re install works on the video.
    examples
    RemovedirtMC ( 14 is even better than 50 didn't do much i tried all parameters )
    Examples bellow
    I am amazed about devcr it is not even blurring that much like others scripts and it is fast by the way
    Another round with devcr with settings 10 it seems that lower number is harder filtering
Name:	slika filter devcr.png
