Pls. advise me tools for authoring DVD that keep audio in AC-3 with max.bitrate at 640 Kbps. Thank so much in advance.
Results 1 to 10 of 10
640kbps?
No.
Follow the DVD-Video specs.Want my help? Ask here! (not via PM!)
I converted a bunch of CDs to AC3 640 kbps, and then use GfD to author them, as "audio titlesets".
These played fine on my DVD player, and a friend's I tried it on.
Since these are actually DVD video files, muxing a static image with the audio, I expect GfD could use the the same kind of audio with a normal video file. But I haven't tried that.
Apparently out of spec, but may play regardless. -
I'm glad it happened to work for you AlanHK, but I would expect it to NOT work correctly for many/most users and would NEVER recommend it.
BTW, what was the sample rate for those conversions? Before-the-fact was surely 44.1kHz, after was it 44.1kHz or 48kHz?
It could also be that as "Audio Titlesets" this may conform to the DVD-Audio spec (and if so, you could tell because the data would mainly exist in *.AOB files in the AUDIO_TS folder), and that spec may have more compliant options WRT bitrates and/or sample rates.
Scott -
48000 of course.
I only used the 640 kbps for a purely audio collection of all 14 Beatles' albums, there was enough space to fit on a DVD at maximum bitrate (about 3 GB I think) so I gave it a try and it worked.
(Of course I couldn't hear the difference between 480 and 640, and I doubt anyone could, so it's overkill.)
If you want 640 kbps AC3, just try it.
What you "expect" may or may not be what actually happens.
You couldn't do it for a commercial DVD, but it works on the (small number of) DVD players I've tried it on.
No. As I said "these are actually DVD video files, muxing a static image with the audio." So it's VOB files in the VIDEO_TS folder. Work on any DVD player. (Certainly on normal bitrates).
See http://download.videohelp.com/gfd/Help/AudioTitleset.html
I often use it to add an OST album to a DVD of the relevant show/film.
I adapted the script it uses and also use it to make my own single image videos, for instance, to create an MPG from a podcast (MP3 converted to 128 kbps AC3) to add to a DVD video compilation. Just adds a few MB overhead, much less than making a normal fps black screen video, for example. -
Ac3 448kbps is the maximum u can dream about in dvd specification and authoring. 640kbps is meant for bluray authoring.
This is the likely scenario:
Somebody downloaded a copy of some MKV movie, from Blu-ray rip, which has untouched audio.
Person converted to "DVD" in whatever encoder/all-in-one. He also wants to keep untouched audio.
But that's not possible, given the restraints of DVD-Video specs.
Two options:
(1) Buy the Blu-ray. <-- preferable option
(2) Downconvert the audio.Want my help? Ask here! (not via PM!)
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 16:42 -
Problem with Megui Maximum bitrate
By yaoyao0204 in forum Video ConversionReplies: 2Last Post: 17th Feb 2012, 11:57 -
Maximum bitrate for DVD with MKV file
By elmuz in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2011, 12:28 -
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 08:25 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 10:11
