  1. Looking for a new surround sound system for a motorhome. I don't need anything really expensive. Prefer to spend $300 max. But the feature I really want/need is all messages/info/setup be done via ONSCREEN menus. Not tiny display windows that I can't see from across the room.
    Thanks for reading and offering any/all advice.
    Regards
    Boowho??
    Oct 2005
    666th portal
    in order to get on-screen menus you will need to buy an a/v receiver as the video will have to pass through it to get anything on the screen. there are lots of them out there, but getting one and 5-9 speakers and a sub for 300 might be tough.
  3. Originally Posted by aedipuss View Post
    Yep, I figured it out based upon your reply. Walmart has a Yamaha "cheapie" unit that has the OSD for $129.
    Thanks for the help.
    Boowho??
