    Mar 2002
    lancashire
    :cry: hello all
    just brought a dvd player its jvc xv-s42 player it will play vcds but will not play svcds is there any hack codes or region code to make it play these svcds or is it just not possible help needed looking around for days
    help needed thanks
    ian
  2. You should have checked the "DVD Players" - lists before you bought.
    You will find the list on this screen to your left (the brown area) below "OTHERS".
    And: no hacks, no codes, buddy.
