I am currently converting video clips to put onto my Ipad2.....I am using DVD shrink to rip the clips from DVD, then editing them with VideoReDo Plus and then converting them to H264/AVCMpeg4 format using Total Video Converter......Although it is working and I can veiw them on the Ipad, there are a couple of problems Im hoping you guys can help me with.....Firstly the thumbnails of the clips on the Ipad are a funny "negative" type of picture......secondly on some movement on the clips, ie a car chase, Lines appear on the screen, I have seen a similar problem years ago when i converted VHS to DVD and with your help it was an interlacing problem, could this be the same issue.......Aside from these problems, could you guys tell me the BEST format to pay videos on an Ipad.......I hope this makes some sense![]()
Try handbrake instead of total video converter. Use the ipad2 preset.
If you still get lines enabled deinterlacing in handbrake. -
A little bit more info, after another look, the lines are appearing in the VideoReDO playback screen as I edit....Is this a sign that thr program isnt up to much or something I may have to live with....also the DVD clip is from a R1 DVD......Thanks for helping me out
How to play native avchd files on ipad2
By merovingio in forum Video ConversionReplies: 2Last Post: 5th Oct 2011, 16:55 -
Convert AVCHD (MTS) to IPAD2
By merovingio in forum Video ConversionReplies: 1Last Post: 3rd Oct 2011, 04:50 -
MKV to compatible extention for Ipad2
By Zhuge Liang in forum Video ConversionReplies: 1Last Post: 22nd Jun 2011, 16:01 -
ipod problem,video clips converting
By ianskill in forum Video ConversionReplies: 5Last Post: 23rd Apr 2009, 16:58 -
Best storable formatt for future editing projects
By mpalm887 in forum Newbie / General discussionsReplies: 21Last Post: 27th Dec 2007, 17:10
