Page 8 of 20
FirstFirst ... 6 7 8 9 10 18 ... LastLast
Results 211 to 240 of 585
  1. Thanks aazerty...
    Now I've installed PHP correctly, and entered the command you gave me in the command prompt, and I'm getting this message:
    "Could not open input file: AdobeHDS.php"
    Any helpful suggestions for a novice?
  2. Hi iucundus ,
    The process below is :
    _ free
    _ without needing JAVA etc.
    _ PORTABLE
    _ under Win XP <= my use
    Keep in mind : 'PHP' needs sometimes other DLL and 'php.ini' has to be modified to run .
    1st step : INSTALLING
    Download 'php' at :
    http://www.mediafire.com/download/85a2dvag8a7o6io/php.rar
    EXTRACTING
    Right click on 'php.rar' ; 'Extract to' ;
    In 'Select to' write : 'C:\php' , and ok .
    in "c:\php" create a batch file ( Upd.bat ) ( see below ) , for updating AdobeHDS.php
    @echo on
    php AdobeHDS.php --update
    pause
    :end
    EDIT 14 jan 2015
    or DL directly the last one
    https://github.com/K-S-V/Scripts/blob/master/AdobeHDS.php
    click on the button 'Raw'
    ( or go at https://raw.githubusercontent.com/K-S-V/Scripts/master/AdobeHDS.php ) .
    Save the file as 'AdobeHDS.php'
    Open Firefox
    Paste the link : https://addons.mozilla.org/en-US/firefox/addon/hds-link-detector/
    Click on the button "Add to Firefox" , for installing .
    After , an icon "HDS Link Detector" will appear in the right-upper corner
    2nd step : RUNNING
    _ Open Firefox
    _ Click on the icon "HDS Link Detector" to enable it
    _ Paste the link of your video and run it
    _ At the beginning for the video , a small dialog box , will appear (on the right) over the task-bar . Click on it !!!
    _ Stop the video
    _ Open a text editor , paste the text got just previously .
    (example : php ... Firefox/34.0" )
    _ finalize your batch file , to be saved in "c:\php" !!! Example 'Z_Hello.bat'
    @echo on
    pause
    :end
    Launch your batch file 'Z_Hello.bat' .
    Wait until the DL is finished .
    Regards .
  3. Originally Posted by iucundus View Post
    Hi folks!
    I've tried the various programs and methods indicated above, and have made great progress in getting nowhere...
    Would anyone be able to help me download this RTE programme please? http://www.rte.ie/player/gb/show/10350147/
    There are only a few days of availability left, so I would be most grateful for help - thanks!
    Getting this now won't be long,i'll edit this with a link
    EDIT:Link http://uptobox.com/eu6a2dz3tsab
    Press create download link then click here to start your download
  4. (for whatllido)
    http://uptobox.com/i6exu7mpnae3
  5. Hi all,
    hate begging like this but i'm having trouble d/ling a vid on rte player.
    http://www.rte.ie/player/ie/show/10356074/
    I can use rtmp for most sites but i think the geolock has the better of me on this occasion as I'm not in the Emerald Isle.
    Any uploader with proper skills willing to help me out?
  6. aazerty, rteripper... Thank you so much!
    I am in awe...
  8. Hi ,
    @sysanin : thanks for the link "http... .mp4" .
    From it I have made a batch file using php .
    php AdobeHDS --manifest "http://vod.hds.rasset.ie/hds-vod/2014/1217/20141217_rtetwo-smackemupr_cl10356074_10356075_260_drm_/manifest.f4m" --delete
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
     Available: 1024 512
     Selected : 1024
    Fragments Total: 752, First: 1, Start: 1, Parallel: 8
    Downloading 752/752 fragments
    Found 752 fragments
    Finished
    => 2272f2ccfc5feba9a2a0108435d8617c_20141217_rtetwo-smackemupr_cl10356074_10356075_260_drm__1024kSeg1-Frag.flv
    renamed ==> smackemupr_0.flv
    Possibility to change ( in the batch ) the quality if needed !!! By adding :
    --quality 512
    Cheers .
  9. Originally Posted by discostoo View Post
    Hi all,
    http://uptobox.com/np1cxzi17l3x
    I have a programme that will download off the rte player 1024k,but that remains a secret not rtmp or batch files
    Happy xmas all and have a wonderfull new year
  10. Hi all,
    I'm having trouble downloading from RTE radio player, what I thought would be a simple enough process looking for the .swf file...
    Had no luck with RTMPE rip before as I'm on a mac and the software was only for windows (was saved by the helpful posters here!) Does anyone have experience downloading from the radio player?
    This is the programme I'm trying to get: http://www.rte.ie/radio/utils/radioplayer/rteradioweb.html#!rii=17%3A10357123%3A18710%...2D12%2D2014%3A
    Any help or advice very much appreciated!
  12. Thanks for the URLs sysanin!
    Still no luck however - the best I've managed to get so far is connecting and then "rtmp server sent error", "rtmp server requested close"
    I'm obviously doing something wrong with the URL but the more I change it the worse it gets. The radio URLs are slightly different to the video ones so I could be cutting out the wrong parts.. I'm a bit of a noob at this!
  13. Hi ,
    This link is good
    youtube-dl "http://vodhls.rasset.ie/hls-vod/audio/2014/1226/20141226_rteraidion-seirbhsche_cl10357123_10358669_261_drm_/20141226_rteraidion-seirbhsche_cl10357123_10358669_261_drm_.mp4.m3u8" -o seirbhsche.ts
    This link is bad
    "rtmpe://...drm_.mp4"
    Cheers .
  14. Originally Posted by cakebox View Post
    Hi all,
    Lol. By the time you find someone capable of finding the link you could have recorded it with Audacity.
  15. Hi ,
    @sysanin : Exact ; the links works with livestreamer . Thanks .
    Regards .
  16. should have worked with rtmp+explorer
  17. Originally Posted by transporterfan View Post
    That is true! Figured I would worsen the quality with Audacity somehow. Got the pm - thank you so much!
    I was using rtmpdump, it was the only one I could find for Mac, but was inputting the URLs wrongly somehow, different error messages each time.
    Thank you everyone for all of your help! Great helpful posters on this forum and this thread.
  18. Rteripper, I'm in awe. Thank you very much, have an excellent New Year.
  19. Originally Posted by rteripper View Post
    as you like
    rtmpdump -r "rtmpe://fmsod.rte.ie:1935/rtevod" -a "rtevod" -f "WIN 16,0,0,235" -W "http://www.rte.ie/static/radio/radioplayer/osmf2_2014_08_19.swf" -y "mp4:/audio/2014/1226/20141226_rteraidion-seirbhsche_cl10357123_10358669_261_drm_/20141226_rteraidion-seirbhsche_cl10357123_10358669_261_drm_.mp4" -o "20141226_rteraidion-seirbhsche_cl10357123_10358669_261_drm_.flv"
  20. Originally Posted by biezom View Post
    as you like
    Lol i don't need it was just saying,anyway usefull for others cheers
  21. Would it be possible to get a 1024k copy of this: www.rte.ie/player/ie/show/10361001/
    I was able to use the instructions in the first post to rip a 512k copy, thanks so much!!!!
  22. Originally Posted by sorross View Post
    Getting it in HD for you
    EDIT: http://uptobox.com/260c7lut3ell
    Press (create download link) then (click here to start your download) enjoy
  23. Incredible, thank you so much!!!
  24. Hi Great tutorial, but I keep getting an "Unable to Download manifest error"
    I can access the manifest through the browser but for some reason the command prompt can't seem to reach it.
    Anyone have any Ideas, any help would be greatly appreciated.
  25. Originally Posted by Faber View Post
    ok could you point out which tutorial please
  26. Originally Posted by rteripper View Post
    This one:
    Download 'php' at :
    EXTRACTING
    @echo on
    pause
    :end
    Open Firefox
    2nd step : RUNNING
    _ Open Firefox
    _ Stop the video
    @echo on
    pause
    :end
  27. Okay so I got it working .
    The adobeHDS.php file in the media fire link didn't work for me so I got a version from
    and that worked.
  28. Hi Faber ,
    Thanks for the reply . Just for my knowledge :
    > The adobeHDS.php file in the media fire link didn't work for me ...
    Have you tried the batch file : php AdobeHDS.php --update
    Before trying to DL from "https://github.../AdobeHDS.php"
    Cheers .
    JE SUIS CHARLIE !!!
  29. The version of AdobeHDS in that link dosen't have an update switch , well it didn't have one for me anyway
  30. Forget all that just use (Streaming Video Recorder) version 4.9.2 (open it up before you open rte player) play the programme on the rte player that you want to download and it will capture the ads the 512k and the 1024k,you can see the files when fully downloaded just press open folder bottom right off (Streaming Video Recorder) hover over the files you will see the one with 1024k,it's as easy as that,if it doesn't work the first time close up everything and reopen (Streaming Video Recorder) the rte player and repeat the process,if it works for me it will work for you...
