Results 481 to 510 of 585
The unencrypted files are here: https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/887/652/IH000353928/
but they give a 415 error when you try and access them.
I've tried setting the content type via curl & wget but keep getting the 415 error. -
Can anyone get https://www.rte.ie/player/movie/rt%C3%A9-investigates-scouts-dis-honour/117660200361
The ismv link does not work any more -
With these new restrictions, I have resorted to downloading all of the .dash video and audio segments from RTE programmes (would be happy to share the method if that would help, its not all that advanced), but I don't know how to combine all of these files in to one coherent, watchable mp4.
Does anyone have any suggestions? Or would that new DRM stop that as well? It seems ffmpeg at least recognizes the initial.dash file and its codecs (audio or video), but then fails after the first file, so concatenating doesn't work. Also, in addition to the segments, I have the relevant .mpd and .ismc files downloaded.
Here is how the files look when downloaded:
video=869000.dash
video=869000-0.dash
video=869000-1200.dash
video=869000-2400.dash
audio=96000.dash
audio=96000-0.dash
audio=96000-94208.dash
When I try to put the .mpd file through ffmpeg, I guess I was able to download some dash video segments (youtube-dl was apparently blocked from downloading the .mpd and just downloading, concatenating as normal) and was hoping to combine/concatenate them so I could watch in VLC, perhaps using ffmpeg. I was able to download the relevant .mpd and .ismc files, so I have all of the DASH video and audio segments, as well as the .mpd and .ismc downloaded and in one folder.
The video files are labelled as such
video=869000.dash
video=869000-0.dash
video=869000-600.dash
and the audio in a similar fashion
audio=96000.dash
audio=96000-0.dash
audio=96000-96225.dash
NOTE: When I try to put the .mpd file through ffmpeg, it returns "Failed to open an initialization section in playlist 0". I would've assumed this initialization was the video=869000.dash file though (which is the one segment file ffmpeg does read)?Last edited by ncmags555; 10th Dec 2019 at 23:40.
With the .mpd (easily found with Dev Tools) and .ismc open, you have the necessary information, including the various bitrates available for video (869000 in my example) and audio (96000 in my example). The video segments seem to go up in steady increments (-1200 in the above file) and you can see the number of segments in the .ismc file. Using that, you can just prepare the links (-1200, -2400, -3600...etc) in a spreadsheet or something and use whatever batch downloader is easiest for you.
So I just made a batch file using youtube-dl, though there are probably easier ways
Like this:
youtube-dl [URL]/video=869000.dash
youtube-dl [URL]/video=869000-0.dash
youtube-dl [URL]/video=869000-1200.dash
youtube-dl [URL]/video=869000-2400.dash
Audio is slightly more difficult as it is not steady increments, but not too bad, as again all info is in the .mpd file. You'll see a long list (the number of which corresponds to the total number of chunks) of similar numbers under <SegmentTimeline> (lets say 94207, 94208, 94206 in the example I gave above). So if it the first number under <SegmentTimeline> is 94207, then 94208, then 94206, your links would be as follows.
audio=96000.dash
audio=96000-0.dash
audio=96000-94207.dash (0 + 94207)
audio=96000-188415.dash (94207+ 94208)
audio=96000-282621.dash (188415+ 94206)
and on like that for the total list of chunks -- again, much easier to do in a spreadsheet and then download using the batch downloader. Hope that makes sense, I think there are easier ways to do all of that just using certain tools, but I'm not familiar with those.
Unfortunately though, at the moment, this isn't much use as I don't know any way to turn those chunks in to a playable file. AdobeHDS used to work great for combining fragments, and youtube-dl clearly has some sort of method to do this, but I haven't found that for this .mpd yet.Last edited by ncmags555; 11th Dec 2019 at 10:48.
I don't know much about encryption (as I'm sure you can tell) but the first .dash segment on both the audio and video (video=869000.dash and audio=96000.dash) can be opened and played in ffmpeg (though it is very small, so I'd imagine is just there for initialization purposes). Generally speaking with encrypted files wouldn't this be impossible?
Below is the metadata from ffmpeg on that first dash segment. If I try on any of the subsequent fragments, I get "could not find corresponding track id" and "moov atom not found"
If I change the segment endings from .dash to either .m4s or .ts and then try to convert and concatenate, I do actually get the video with the proper length, though the video is all gray and screwed up (though it does appear with the proper dimensions)...I'm not sure if that is the encryption kicking in or just the fact that ffmpeg was reading .dash as .ts or .m4s and thus converted it incorrectly or something like that.
video
audioCode:Metadata: major_brand : iso6 minor_version : 0 compatible_brands: iso6dash Duration: N/A, bitrate: N/A Stream #0:0(und): Video: h264 (avc1 / 0x31637661), none, 1280x720, 600 tbr, 600 tbn, 1200 tbc (default) Metadata: handler_name : USP Video Handler encoder : AVC Coding Output #0, mpegts, to 'asdsdadadsds.ts': Metadata: major_brand : iso6 minor_version : 0 compatible_brands: iso6dash encoder : Lavf58.27.103 Stream #0:0(und): Video: h264 (avc1 / 0x31637661), none, 1280x720, q=2-31, 6 00 tbr, 90k tbn, 600 tbc (default) Metadata: handler_name : USP Video Handler encoder : AVC Coding
Code:Metadata: major_brand : iso6 minor_version : 0 compatible_brands: iso6dash Duration: N/A, bitrate: N/A Stream #0:0(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12 8 kb/s (default) Metadata: handler_name : USP Sound Handler [mpegts @ 00000000003b2580] frame size not set Output #0, mpegts, to 'dsaddaddas.ts': Metadata: major_brand : iso6 minor_version : 0 compatible_brands: iso6dash encoder : Lavf58.27.103 Stream #0:0(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12 8 kb/s (default) Metadata: handler_name : USP Sound HandlerLast edited by ncmags555; 11th Dec 2019 at 23:48.
You're downloading the encrypted dash segments.
If the mpd that proceeds the init & segments in the network traffic has drm data, then the segments called subsequently are those drm'd segments.
If the init file and the first segment file are concatenated, mediainfo (tree view) should report the encrypted status. -
Ah OK, thanks for that...yes mediainfo seems to prove it.
I know next to nothing about that stuff, though I suppose you would need to find a way to emulate the handshake that occurs when playing it on the actual Player (between what, I don't know) in order to make any of it work. rtmpdump and get_iplayer seemed to have this ability back in the day, but I'm out of my league now it seems.
Code:General Complete name : 869000.dash Format : iso6 Codec ID : iso6 (iso6/dash) File size : 1.58 KiB Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : encv / avc1 Codec ID/Info : Advanced Video Coding Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Encryption : Encrypted Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC
If anyone needs help with rte, I might be able to help, you can send me a message
Hey guys.
Some of you helped me out a couple of pages/years back with downloading from RTE using youtube-dl and it was working great.
It's been a while though and I tried again recently but It looks like RTE player has changed and I wasn't able to get it working.
Is it no longer possible? (above post suggests it might be, but the user is banned).
I'm trying to download this archive footage. https://www.rte.ie/archives/2020/0319/1124136-italia-90-coverage/
I have also been trying to download from the Virgin Media player and it seems they use brightcove for content delivery. Is it possible to download from here at the moment? For example, this news clip? https://www.virginmediatelevision.ie/player/show/633/171756/0/News-at-12.30
Thanks a lot in advance.
what is your problem? yt-dl work great with both links...
you have to get m3u8 file then put on yt-dl. no problem to download. -
Hey. I haven't been able to find the m3u8 links like I used to.
I assumed they changed the protocol used or something. Can you explain how you get them?
Thanks.
EDIT:
Sorry, that virgin link might been a bad example. I just grabbed whatever was on the front page. It seems some videos have manifest.mpd links instead of m3u8.
I just did a quick check and found this example that I can't find th m3u8 link for. https://www.virginmediatelevision.ie/player/show/1866/171110/0/The-Guards%3A-Inside-the-KLast edited by RTE; 24th Apr 2020 at 09:06. Reason: Better example.
If you get the stream detector you can get the manifest m3u8 l and use that with yt/dl
How to download flash video RTMP/RTMPE streams using free software
By Baldrick in forum User guidesReplies: 4609Last Post: 6th Mar 2025, 11:32 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 15:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 22:37 -
ripping dvd's with rip-it
By XAPHSNYC in forum MacReplies: 10Last Post: 31st Jan 2010, 22:59 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 11:37
