Hi, I'm trying to download this video
http://mwave.interest.me/mnettv/videodetail.m?searchVideoDetailVO.clip_id=165441
but i get an "access denied! unable to download fragments"
I replaced the adobehds.php file but it still didn't work
can someone help me please?
Results 301 to 330 of 585
Hi i am trying to ripp this video from a swedish site kanal5, ut i get this msg in cmd saying: Unable to download the manifest.
Here is the link i got from url snooper:
http://www.kanal5play.se/flash/K5StandardPlayer.swf?cache=20150210100648.3821339478102...g=hdcore=3.5.0
Have i done something wrong with mine?
php AdobeHDS.php --manifest "http://www.kanal5play.se/z/open/=20150210100648382133947810256228.wvm.csmil/manifest.f4m?g=hdcore=3.5.0" --delete
Hope someone can help, cheers -
Hello, I followed the instructions from #212 posts. But, in step 2.3 (the beginning of the video, a small dialog box will appear (right) during the taskbar) nothing happens. My cursor is flashing, and nothing else happens. I reviewed the previous steps, installed the extension, activated it ... I downloaded the "AdobeHDS.php" upgraded from git repository (https://github.com/KSV/Scripts/blob/master/AdobeHDS.php), saved the same in "C: \ php". The video I'm trying to download is the link: "http://portal.code.education/lms/#/30/15/52/conteudos?capitulo=305&conteudo=1723", but you must have access to both.
Using Mediabox I noticed that the video is streaming from a RTMP. This is the url that the program returned to me. I tried to use the built-in recorder of the same program, but did not work. I tried to use the rtmpdump-2.4, and got no success (the program breaks when you try connectar with the url). The URLSnooper can not even get the url, maybe because I did not set up correctly. Anyway, what method you indicate for this case? I know it's a RTMP straming, the site says is played by JWPlayer.AdobeHDS.php is for .f4m manifest.
Are you sure your video is it in this format?
it is difficult to verify for me without access -
You can indicate some step-by-step guide for this type of streaming? Using these tools you mention. Because so, I've tried using rtmpdump and he gave crash, do not know why.
I tried again using rtmpdump. Got the streaming information through MidiaBox. I used the url in cmd and this happened:
maybe with the last update https://github.com/K-S-V/Scripts/releases/download/v2.4/rtmpdump-2.4.zip
It's recording! Thx
I gave the command when the video was already rolling ... and it is over, but the console nothing has changed. Still recording ... What should I do?
Sorry for the ignorance, I had created a ridiculously wrong command. I corrected looked like this: "rtmpdump -r" rtmp: //mediabr3.estadovirtual.com.br: 1935 / schoolofnetdesktop / mp4: /SASS/1/SASS-1.1-Falando on CSS.mov "-the FalandoSobreCSS.mov" . To run it he created the file in the directory, but he's 0kb. Is that so?Last edited by Dagdelo; 13th Feb 2015 at 22:34. Reason: Questions of newbie
The biggest problem is that the 64-bit version RTMPHelper can not work with my browsers. You see the error that appears:
I need to find a 32-bit browser for my 64-bit system. Does anyone know where I can?
Ok, after reading a little more of RTMPHelper documentation found that the version I'm using is 64-bit. When he should be using 32 bits. So my browsers are 32-bit (although the system is 64-bit). Anyway, I got hit with firefox, but not Chrome. What is already a good size, for those who could not with any.
What should I do now?Last edited by Dagdelo; 14th Feb 2015 at 23:05.
You can download that video with ChrisPC VideoTube Downloader Pro, actually it's a RTMP stream: http://downloadvideo.how/
Hello Mike, I succeeded download the videos using the RTMPHelper + RTMPDumper. The Helper generated the command and I just did add a streaming parameter (-v) to it. But I loved the hint, surely one day I will use it.
The code seemed very complex. For there are many new parameters, such as session, id, token's ... Anyway, if not for the Helper could not download the video.Code:rtmpdump -v -r "rtmp://mediabr3.estadovirtual.com.br:1935/schoolofnetdesktop/" -a "schoolofnetdesktop/" -f "WIN 16,0,0,305" -W "http://portal.code.education/bundles/sonbase/ev-player/Player.swf" -p "http://portal.code.education/lms/#/30/15/52/conteudos?capitulo=304&conteudo=1717" -C O:1 -C NS:idsessao:s7g0dr6o2ep8q78ji3shtegim0 -C NS:idusuario:590 -C O:0 -y "mp4:/SASS/1/SASS-1.2-PreProcessadores.mov" -o "2015-02-15_01-57-43_SASS-1.2-PreProcessadores.flv"
Hello all.
Can you help to record this "stream" ?:
https://techdays.microsoft.fr/live/?td=2
URL Snooper gave me this link:
https://live-secure.brainsonic.com/microsoft/techdays15/j3/files/swf/playerHds.swf?dep...t.fr%2Flive%2F
But i don't kwnow how to proceed to record this video.
Thank you -
Hi Klonac ,
Here below my try .
Batch file
=== Process ==== Faut pas ętre pressé !!!Code:@echo on php AdobeHDS.php --manifest "https://bms03a-pad.brainsonic.com/bsl_loc/tdj2bck02_2/manifest.f4m?DVR" --delete --useragent "Mozilla/5.0 (Windows NT 5.1; rv:35.0) Gecko/20100101 Firefox/35.0" --outfile Tech_Days.flv pause :fin
Only jingle music during the first 20mn .Code:KSV Adobe HDS Downloader Processing manifest info.... Quality Selection: Available: 1 Selected : 1 Fragments Total: 9734, First: 1, Start: 1, Parallel: 8 Downloading 28/9734 fragments ... Not finish !!! ================
Cheers .Last edited by aazerty; 16th Feb 2015 at 10:35.
JE SUIS CHARLIE !!! -
Merci pour ton aide aazerty.
Some questions:
1)How did you find this link? : https://bms03a-pad.brainsonic.com...............
Answer: HDS Link Detector Add-on
2) This stream is a record of one day of techdays 2015. But i only interested in some parts of video and not to download the whole stream.
For example between 2hour and 3 hour from the video.
How proceed ?
--start [param] start from specified fragmentLast edited by Klonac; 16th Feb 2015 at 14:40. Reason: answers
Hi Klonac ,
Yes ( Oui )
https://addons.mozilla.org/en-US/firefox/addon/hds-link-detector/
Never tried . If the choice is bad we have to try again .
( Quel numéro choisir ? Si c'est mauvais on doit tout recommencer !)
The best way is to DL the file completly .
After use FFMPEG to cut it .
start=num
Start at num seconds into the stream. Not valid for live streams.
stop=num
Stop at num seconds into the stream.
Cheers .JE SUIS CHARLIE !!! -
Hi folks!
1st post here (apologies, please don't scroll on by...) and I'm in need of help. I'm pretty competent when it comes to these things but this one has stumped me! I am trying to grab video from the EPiXHD site. I managed to get various amounts of links/info including the manifest file which originally I saved to my laptop, opened it and had a read through, etc just to see what it said. I ended up here (and other places) after searching for how to grab the contents from a manifest file. So I ended up downloading the AdobeHDS.php script and testing it out. I also installed the HDS Link Detector for Firefox. This is where I am at the moment...
I managed to test out AdobeHDS.php script and it works fine. Successfully managed to download some video (I tested it on a link in this thread). The thing is, it wasn't from EPiXHD. I get an, "Access Denied! Unable to download the manifest." error when I try that. So, I thought I would change the link in the command prompt from the EPiXHD site to the manifest file I have on my laptop as I managed to download that no problem... didn't work! After a few seconds, I get an, ""Processing manifest info.... Unable to download the manifest" error. Things looked as if they were gonna work because it took a couple seconds to throw up the error. So, I decided that something else must be wrong. I guessed that it may be because the EPiXHD site needs an account to view the content... I decided to test it out.
I logged out of my account, cleared cookies, etc and then, as I still had the url of the manifest, I pasted it in my browser and it threw up an "Access Denied!" error. I then knew I needed to be logged into my account for it to download and that is why the AdobeHDS.php script wasn't working.
So, apologies for the long-winded explanation but is there a way to grab the content from the EPiXHD website via the AdobeHDS.php script? Can I input my login details into the php script or something? Also, I'm in the UK and the site needs a US proxy. Been using a VPN to watch with no problems but wondered if that may affect things too and if there is any way to bypass that?
Thanks for reading, any other info I can give you, I shall.
EDIT: Just a little update. I managed to get AdobeHDS.php to process the manifest file from the server via the --proxy option. After a second or two, I got this:
...so, I managed a step further than previously I had done but I'm still thinking I need the AdobeHDS.php script to use my login details so I can download the fragments. Any ideas?Code:Processing manifest info.... Quality Selection: Available: 3462 2145 1650 1186 741 445 Selected : 3462 Fragments Total: 539, First: 1, Start: 1, Par Access Denied! Unable to download fragments.
EDIT 2: Success!!! I had to use the --fproxy setting for the fragments as well... silly me. I now have the full 720p HD file on my laptop which I muxed to mkv.Last edited by irn-bru; 16th Feb 2015 at 19:51. Reason: Managed to work it out myself.
This video is long "10:09:42" and contains 9734 fragments.
I want to record from 8:49:00 to the end. So I apply a rule of 3 and I get 8445 fragments.
So I use as an argument "--start 8445".
Also I can combine the options "--start" and "--duration [param] stop recording After specified number of seconds" to choose a specific time of the video.
start=num and stop=num: this options are for rtmpdump and not for AdobeHDS.php ??? -
Hi Klonac ,
Thanks !!!
( Merci pour les infos !!! )
Just for the general knowledge : when we have in our 'FF's cache' the file 'manifest.f4m' ,
openning it , we can see the exact duration of the video and qualities able .
Code:php AdobeHDS.php --manifest "https://bms03a-pad.brainsonic.com/bsl_loc/tdj2bck02_2/manifest.f4m?DVR" --start 8400 --delete --useragent "Mozilla/5.0 (Windows NT 5.1; rv:35.0) Gecko/20100101 Firefox/35.0" --outfile Tech_Days_reduit.flv
1) I have told '--start 8400'Code:KSV Adobe HDS Downloader Processing manifest info.... Quality Selection: Available: 1 Selected : 1 Fragments Total: 9734, First: 1, Start: 8400, Parallel: 8 Downloading 9734/9734 fragments Found 1335 fragments Finished
2) It works perfectly
3) Thanks for "--duration [param] stop recording After specified number of seconds"
Hi Dagdelo ,
> Or should I download from .flv and convert using another app.
Yes .
How to download flash video RTMP/RTMPE streams using free software
By Baldrick in forum User guidesReplies: 4609Last Post: 6th Mar 2025, 11:32 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 15:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 22:37 -
ripping dvd's with rip-it
By XAPHSNYC in forum MacReplies: 10Last Post: 31st Jan 2010, 22:59 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 11:37
