Results 421 to 450 of 585
Unlikely they provide a better version from their site. According to their FAQ, all the available resolutions are offered for manual selection in their player, and the 2048 kbps (1024x576) is the best one I've seen there. https://www.rte.ie/player/ru/help/faq/
Hello, here I go again. I tried stealing a video from RTE player with youtube-dl, which usually normally works for me, but no matter what i do, it doesnt connect. And my command line seems to be broken. Tried it in Win Powershell. I am hoping to download in best possible quality and also have to use a proxy as im not in Ireland or the UK. Any suggestions on what might work without command line? Not sure how much time there is left for this one....
Thank you so so much in advance!
https://www.rte.ie/player/cz/show/other-voices-406/10827765/
Edit: Now also my powershell says "The screen cannot be set to the number of lines and columns specified". so i guess its no longer working too?Last edited by wile.e.coyote; 27th Feb 2018 at 10:46.
This particular program is geo-blocked. To download it with youtube-dl you need:
1. Edit the URL by replacing cz with ie:2. Find a working Irish proxy, even a slow one will be OK for your needs.Code:https://www.rte.ie/player/ie/show/other-voices-406/10827765/
3. Open the page for the episode 1 (if your proxy is OK, ie will still be shown in the next page's URL + no warning about your location).
4. Start playback and find the link to the f4m manifest (2048 kbps version), previously having used F12 key (browser developer tool opens - use its Network tab).
5. Use that link in youtube-dl, the proxy is not needed anymore. -
Hey all. I'm a noob at all this. About 2 years ago I had a program on PC that could rip RTE player, successfully got a few bits. Now I'm on mac and can't remember what it was called. I'm almost certain it was made by an Irish guy - any ideas what it was called?
Would anyone do me a huge favour and rip 2 shows for me? I would really, really appreciate it. Thanks in advance.
https://www.rte.ie/archives/2018/0809/984038-ballroom-to-disco/
https://www.rte.ie/archives/2017/0522/877128-dublin-dance-club-sides-dc/ -
wow. thanks a mill LZAA. thats's super cool of you. god bless the internet and you techy types
Can anyone recommend a VPN that works for streaming RTE Player from the UK ?
Really struggling to find a way to download from the RTE Player from the UK. I previously had a few apps that would do this but I spent several hours this morning downloading and trying different methods without any luck at all.
I'm trying to download the following programme:
https://beta.rte.ie/player/movie/nathan-carter-3-arena-live-show/85825064169
Can anyone help please ?
Thanks in advance -
Hi HappymanUK ,
Do a search on youtube for :
nathan carter live 3 arena
Below an example :
Nathan Carter - Beeswing (Live at the 3 Arena 2018) - YouTube
https://www.youtube.com/watch?v=qqwsAC0hj9Y
Cheers .JE SUIS CHARLIE !!! -
i think RTE have changed their system. The beta in the url suggest this too. I used to be able to download from rte with youtube dl now i can't. And i am in Ireland.
EDIT says to me your url does not exist -
Hi Guys
Trying to download off the new rte player, have used older methods before and have worked but since Christmas they have changed their player
https://www.rte.ie/player/series/first-dates-ireland/SI0000000596
Can anyone help please to get back downloading off the player? -
I am currently trying to download bachelors walk for the Mrs and have found a way to get the files but it's a real pain in the arse manual way, maybe someone here has an idea on automating it.
1) Go to the series you want to watch and
2) In firefox press f12 to open the developer console
3) Go to the Network tab in the developer window
4) select the episode and then press play
5) watch the console and select one of the lines when your episode is playing, on the RHS you will see request URL eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/M3646081-1541685509261.ism/da...iry=1603350000
6) edit this URL back to the 1st IPXXXX folder eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/
7) put this in the browser and select the largest file there and it will download a file in .ismv format eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/M3646081-15416769273112496_dc...f85bf7672.ismv
8) this can be played in VLC or mp4 format can be extracted from it (google it eg ffmpeg - https://ffmpeg.org/ffmpeg-formats.html#mov_002c-mp4_002c-ismv)
hope this helps -
Many thanks for this. There's a show I've been after for ages.
The sound is in the ismv file.
Convert the ismv file to an mp4 using ffmpeg and the sound synchs.
ffmpeg -i FILENAME.ismv -codec copy -f mp4 -y FILENAME.mp4
Are the subs hardcoded? I can't seem to get rid of them.
Update
The TG4 contents subs are hardcoded.
The first file on the [vid] list is a 360x640 mp4 file with sound already synchedLast edited by daigo99; 10th Feb 2019 at 20:57.
Thanks, All the links I pulled work for me using VLC no problem, I did find sometimes I needed a double // after RTE_Prod_-_Prod as per below to find the storage folder
https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod//69/348/IP9706/ [*this link will not work and is for illustrative purposes only*] -
streamlink "hls://https://cdn.rasset.ie/manifest/2019/0225/20190225_webexclusi-clairebyrn_cl11007205_11007206_ih000367740_260_/manifest.m3u8" best -o video.ts
Hey guys, I'm not looking to rip video, but audio. Is there a way to download from radio player?
I have tried a lot of things.
I ended up using another PC to record the audio of each show I wanted, as it streamed, which is the very last option, and it takes the full length of each show.
I have so far got 7 shows, but now RTE site won't load properly on the PC anymore, I guess a clearing of history may helpm but want to back it up first.
I stumbled upon this thread/forum purely by accident. It would be great if it was possible. I am reading over the thread but it is a big one. -
Thanks for reply
I have an ismv not ts but i got it with this code ffmpeg -i input.ts -c copy -bsf:a aac_adtstoasc output.mp4 and it was few mins to convert 1 gig file ffmpeg -i input.ts -c copy -bsf:a aac_adtstoasc output.mp4
ffmpeg -i SOURCEFILENAME.ismv FINALFILENAME.mp4 took hours to convert a 2.2 gig file
How to download flash video RTMP/RTMPE streams using free software
By Baldrick in forum User guidesReplies: 4609Last Post: 6th Mar 2025, 10:32 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 14:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 21:37 -
ripping dvd's with rip-it
By XAPHSNYC in forum MacReplies: 10Last Post: 31st Jan 2010, 21:59 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 10:37
