Results 361 to 390 of 585
Lads,
I've run into a bit of a problem. Just moved to NZ and trying to download stuff off RTE Player, namely:
http://www.rte.ie/player/ie/show/second-captains-live-30002430/10476561/
I get redirected to:
http://www.rte.ie/player/nz/show/second-captains-live-30002430/10476561/
and the following message
"Sorry. This content is not available to watch based on your current location."
No suprises there, exactly what I expected.
Figured it'd be easy to use a VPN and everything would be hunky dorey, been doing it for ages for BBC iPlayer. I've tried using TunnelBear with an Irish VPN but I get redirected to:
http://www.rte.ie/player/99/show/second-captains-live-30002430/10476561/
and the same error message.
Any suggestions would be greatly appreciated. Thanks -
EDIT: sorry, I replied by mistake
It seems RTE's switch to Mii Solutions for stream hosting is causing issues. I'm ripping this and Livestreamer continually reports "Failed to parse fragment" errors but soldiers on anyway, which, I assume, means the final file will be rather jittery due to missing data, while YouTube DL simply stops the download upon encountering a urlopen (getaddrinfo failed) error, which means babysitting the process as I need to reissue the download command anywhere from 0.1% to a few percent later.
Annoying, to say the least.Last edited by RequiredInformation; 24th Oct 2015 at 15:53.
AnonymousGuest
Possibly (the download speed is dreadfully slow), however I can watch the video on RTE's site just fine, which is the strange thing.
As expected, Livestreamer's file is imperfect, however I've crossed the 60% mark in YouTube DL, so I'm getting there, slowly but surely.Last edited by RequiredInformation; 24th Oct 2015 at 16:34.
Can anyone help me download video stream with this link:
Thank.rtmpe://cp133145.edgefcs.net/ondemand/&mp4:videos/963482467001/201510/3948/963482467001_4558547684001_4558122743001.mp4~ay=cs ma-3.6.5:brightcoveLoader-1.0.27~m=PL~v=440611~aa=cp133145.edgefcs.net~ac=&m p4:videos/963482467001/201510/3948/963482467001_4558547684001_4558122743001.mp4~am=D~ an=740~ao=2553~ap=3293~ar=0~en=Shortland%20Street, %20Series%2024,%20Episode%205863~ft=1~pd=378105852 3001~tt=Shortland%20Street,%20Series%2024,%20Episo de%205863~va=1~ -
Can anyone help me with this show?
http://www.rte.ie/player/ie/show/the-late-late-show-68/10498592/
Thanks -
hi
you can use youtube-dl or livestreamer
orCode:youtube-dl "http://www.rte.ie/player/ie/show/the-late-late-show-68/10498592/"
Code:livestreamer "hds://http://cdn.rasset.ie/hds-vod/2015/1127/20151127_rteone-latelate-thelatelat_cl10498592_10499420_260_drm_/manifest.f4m" best -o Watch-The-Late-Late-Toy-Show-online-10498592.flv
I ripped the video using the youtube-dl "http://www.rte.ie/player/ie/show/the-late-late-show-68/10498592/" command, but I can only seem to open it in VLC player, and not media player. Is it in a funky format or using an odd codec? Any help would be appreciated!
Thanks! -
RTE actually uses different f4m manifest files for different resolutions, so if you just use this link with 'best' switch, the choice will be between 512 and 1024: that first manifest file only contains links to those two. But if you take the 1024 URL from downloaded f4m to next manifest file and simply replace 1024 with 2048 in that link, you will be able to use the link to their 2048 f4m file and download 1024x576 version:
Unfortunately, I still don't know if 720p version is available for delayed LL Show episodes (already tried to substitute other bitrates). RTE usually posts music numbers on Youtube in 720p and their live stream is also 720p (I tried to download 'live' fragments, but they are available for a very short time and can't be joined due to DRM encryption).Code:http://cdn.rasset.ie/hds-vod/2015/1127/20151127_rteone-latelate-thelatelat_cl10498592_10499420_260_drm_/20151127_rteone-latelate-thelatelat_cl10498592_10499420_260_drm__2048k.mp4.f4m
Can anyone please help grab this show in best quality? I'm not from Ireland so getting it to even play is hard enough. I've tried Hulu, Modify Headers and a couple of browser plugins.
What does one need to do this please?
http://www.rte.ie/player/ie/show/the-tommy-tiernan-show-tv-30003801/10510011/
Cheers -
youtube-dl seems to work fine for me with RTE, but does anyone know how to download from TG4 (Teilifís na Gaeilge)?
E.g. News links can be found here: http://www.tg4.ie/en/player/news/ (not region blocked but they expire)
Sample news bulletin: http://www.tg4.ie/en/player/home/?pid=4778518466001&teideal=Nuacht%20TG4&series=Nuacht%20TG4 -
OK, so the latest challenge is that TG4 are moving from hard-coded subtitles to HTML5 ones. Any clues how to save them?
Example: http://www.tg4.ie/ga/player/baile/?pid=4653228713001&teideal=s01e01&series=Na%20Cloigne
(I think this series is up indefinitely). -
You can get this link using AdBlockPlus FF plugin:
http://www.tg4.ie/wp-content/themes/tg4-starter/assets/captions/WCL012122_eng.vtt -
Thanks Alex_ander. A little bit more bash script and I should have it automated.
please help
http://www.rte.ie/player/ie/show/dragons-den-1203/10561363/
need fast ie proxy -
http://www.rte.ie/player/ie/show/the-guards-30004040/10574484/
Can anyone tell me how to download this so i do not have to watch the ads. I searched with adblock and tools/ web developer/network in firefox. i do not see any stream link -
AnonymousGuestCode:
livestreamer "hds://cdn.rasset.ie/hds-vod/2016/0517/20160517_rtetwo-theguards_cl10574484_10574485_260_drm_/manifest.f4m" best -o RTE.flv [cli][info] Found matching plugin stream for URL hds://cdn.rasset.ie/hds-vod/2016/0517/20160517_rtetwo-theguards_cl10574484_10574485_260_drm_/manifest.f4m [cli][info] Available streams: 512k (worst), 1024k, 2048k (best) [cli][info] Opening stream: 2048k (hds)
What about this one http://www.rte.ie/player/ie/show/young-dumb-and-dangerous-30004036/10571816/
Can anyone tell me how to get codes. I looked at page source and used network tools. I t should be similar top the previous one as it is the same station player but i cannot see anything like hds://cdn.rasset.ie/hds
I want to watch this without being force fed ads. Thanks -
please help can't find any working proxy or socks
http://www.rte.ie/player/ie/show/10576336 -
livestreamer "hds://cdn.rasset.ie/hds-vod/2016/0522/20160522_rteone-dragonsden-dragonsden_cl10576336_10576411_260_drm_/manifest.f4m" best -o RTE.flv
How to download flash video RTMP/RTMPE streams using free software
By Baldrick in forum User guidesReplies: 4609Last Post: 6th Mar 2025, 11:32 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 15:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 22:37 -
ripping dvd's with rip-it
By XAPHSNYC in forum MacReplies: 10Last Post: 31st Jan 2010, 22:59 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 11:37
