I've been trying to make a movie made with various frame rates going like 40 to 60, game footage from FRAPS. But there's always a problem when finalizing the movie in my desired frame rate is the end result is choppy.
I tried with blending method but I'm not satisfied as it create very blurry images and desaturate the overall pictures too much from my taste. Is there a better way to make conversion more accurate than letting the software guessing the frames?
You can interlace it which will give you an effective 59.94fps. Using AviSynth, it might go something like this:
AssumeTFF()
Yadif(Mode=1)
ChangeFPS(59.94)
SeparateFields()
SelectEvery(4,0,3)
Weave()
This assumes you're doing something (like making a DVD) where interlacing it is OK. And for Blu-Ray 1280x720, progressive 59.94fps is allowed. For YouTube it's no good. In that case 29.97fps is the highest you can use.
How to convert from 23.747 fps to 30 fps ?!
By SB4 in forum RestorationReplies: 7Last Post: 27th Aug 2012, 01:07 -
Force Higher FPS?
By therock003 in forum Software PlayingReplies: 5Last Post: 18th Apr 2012, 18:26 -
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
how do you lower fps on camcorder???
By aug3r in forum Capturing and VCRReplies: 6Last Post: 9th Jan 2009, 23:48 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
