HI ALL first,
I have a big problem with my Hauppauge WinTv FM in VirtualDub!
I can`t capture with a resolution witch is higher then 352 x 288!, always comes this error: error 418: format is not supported!
I have a WDM driver for this capture card and I am running WinXP.
How can I fix this problem??
I hope somebody can help me...
THX
Chris[/b]
Results 1 to 12 of 12
I use the HufYuf codec version 2.2.2.1
Sometimes I use the mjpeg codec from PicVideo
But I also use DivX 4.12 and 4.11...
Chris -
Please tell me, How it is called (the driver)??Originally Posted by baker
Ich have Windows XP and use the WDM driver from hauppauge.
How can I find it? -
Had you have got WinXp??Originally Posted by baker
Becouse I have Windows Xp and for it you need a WDM driver.
If you hadn`t windows Xp the driver wouldn`t work by me.
If you had have Windows Xp with the driver I will search the driver...
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
VirtualDub Capture Pin problem.. (EasyCap) [SOLVED]
By muzzmikkel in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2012, 12:05 -
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 18:35 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 15:05
