Hello
I've been working my way through my Home DVD collections (DVD 5 & DVD9) ripped to my PC HD, using VOB2MPEG
Then using HandBrake options (h264, RF 20, Decomb Defualt)
Is been going well with my DVD5 collections, but My DVD9 ( a nice 2 week Cox & Kings holiday, my wife and i went on in 2007) Mpeg i've hit a problem
The converted file plays but, (SEE PHOTOS)
http://i45.tinypic.com/1i056d.jpg
http://i46.tinypic.com/o0kys.jpg
There no Total Time showing and show i cant skip to a particular time, i have to use the fast forward which takes time as the clip over 2 hrs
Is this because the files are over 4 GB in size as i did click the large size option, or im i doing something wrong
Orignal Mpeg info
HandBrake ConvertedCode:General Complete name : C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg Format : MPEG-PS File size : 7.67 GiB Duration : 2h 31mn Overall bit rate mode : Variable Overall bit rate : 7 236 Kbps Writing library : encoded by TMPGEnc DVD Author 3 Version. 3.0.5.149 Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Duration : 2h 31mn Bit rate mode : Variable Bit rate : 6 868 Kbps Maximum bit rate : 8 000 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.662 Stream size : 7.28 GiB (95%) Writing library : TMPGEnc / DVD Author 3 Version. 3.0.5.149 DVD Author 3 Version. 3.0.5.149 Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : DVD-Video Duration : 2h 31mn Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 243 MiB (3%) Menu
HandBrake LogCode:General Complete name : C:\Users\bob\Desktop\TEST FILES\India Trip Mar & Oct 2007-1.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 4.79 GiB Duration : 2h 31mn Overall bit rate mode : Variable Overall bit rate : 4 522 Kbps Encoded date : UTC 2012-11-05 01:25:25 Tagged date : UTC 2012-11-05 04:05:55 Writing application : HandBrake 0.9.8 2012071700 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2h 31mn Bit rate mode : Variable Bit rate : 4 358 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Original display aspect ratio : 4:3 Frame rate mode : Variable Frame rate : 25.000 fps Minimum frame rate : 1.667 fps Maximum frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.420 Stream size : 4.62 GiB (96%) Writing library : x264 core 120 Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2012-11-05 01:25:25 Tagged date : UTC 2012-11-05 04:05:55 Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2h 31mn Bit rate mode : Variable Bit rate : 160 Kbps Maximum bit rate : 251 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : 80ms Stream size : 174 MiB (4%) Encoded date : UTC 2012-11-05 01:25:25 Tagged date : UTC 2012-11-05 04:05:54
Code:HandBrake 0.9.8 2012071700 OS: Microsoft Windows NT 6.1.7600.0 CPU: Intel(R) Core(TM)2 CPU T7600 @ 2.33GHz Ram: 3326 MB, Screen: 1920x1200 Temp Dir: C:\Users\bob\AppData\Local\Temp\ Install Dir: C:\Program Files\Handbrake Data Dir: C:\Users\bob\AppData\Roaming\HandBrake\HandBrake\0.9.8.4861 ------------------------------------------- CLI Query: -i "C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg" -t 1 -c 1 -o "C:\Users\bob\Desktop\TEST FILES\India Trip Mar & Oct 2007-1.mp4" -f mp4 -4 --decomb --strict-anamorphic -e x264 -q 20 --vfr -a 1 -E faac -B 160 -6 dpl2 -R Auto -D 0 --gain=0 --audio-copy-mask none --audio-fallback ffac3 -x ref=1:weightp=1:subq=2:rc-lookahead=10:trellis=0:8x8dct=0 --verbose=1 User Query: False [17:25:24] hb_init: starting libhb thread HandBrake 0.9.8 (2012071700) - MinGW i686 - http://handbrake.fr 2 CPUs detected Opening C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg... [17:25:24] hb_scan: path=C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg, title_index=1 libbluray/bdnav/index_parse.c:157: indx_parse(): error opening C:\Users\bob\Desktop\scotland\India Trip Mar & Oct 2007.mpg/BDMV/index.bdmv libbluray/bluray.c:1471: nav_get_title_list(C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg) failed (01BA30B0) [17:25:24] bd: not a bd - trying as a stream/file instead libdvdnav: Using dvdnav version 4.1.3 libdvdread: Encrypted DVD support unavailable. libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed libdvdread: Can't open file VIDEO_TS.IFO. libdvdnav: vm: failed to read VIDEO_TS.IFO [17:25:24] dvd: not a dvd - trying as a stream/file instead [17:25:24] file is MPEG Program Stream [17:25:24] Probing 1 unknown stream [17:25:24] Probe: Found stream mpeg2video. stream id 0xe0-0x0 [17:25:24] Found the following streams [17:25:24] Video Streams : [17:25:24] 0xe0-0x0 type MPEG2 (0x2) [17:25:24] Audio Streams : [17:25:24] 0xbd-0x80 type AC3 (0x81) [17:25:24] Other Streams : [17:25:24] stream id 0xbd (type 0x81 substream 0x80) audio 0x8000bd [17:25:25] scan: decoding previews for title 1 [17:25:25] scan: audio 0x8000bd: AC-3, rate=48000Hz, bitrate=224000 Unknown (AC3) (2.0 ch) [17:25:25] scan: 10 previews, 720x576, 25.000 fps, autocrop = 0/0/0/0, aspect 4:3, PAR 16:15 [17:25:25] Title is likely interlaced or telecined (10 out of 10 previews). You should do something about that. [17:25:25] scan: title (0) job->width:720, job->height:544 [17:25:25] stream: 97 good frames, 0 errors (0%) [17:25:25] libhb: scan thread found 1 valid title(s) + title 1: + stream: C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg + duration: 02:31:37 + size: 720x576, pixel aspect: 16/15, display aspect: 1.33, 25.000 fps + autocrop: 0/0/0/0 + chapters: + 1: cells 0->0, 0 blocks, duration 02:31:37 + audio tracks: + 1, Unknown (AC3) (2.0 ch) (iso639-2: und), 48000Hz, 224000bps + subtitle tracks: + combing detected, may be interlaced or telecined [17:25:25] 1 job(s) to process [17:25:25] starting job [17:25:25] work: sanitizing track 1 mixdown Dolby Pro Logic II to Stereo [17:25:25] sync: expecting 227425 video frames [17:25:25] job configuration: [17:25:25] * source [17:25:25] + C:\Users\bob\Desktop\folder\India Trip Mar & Oct 2007.mpg [17:25:25] + title 1, chapter(s) 1 to 1 [17:25:25] * destination [17:25:25] + C:\Users\bob\Desktop\TEST FILES\India Trip Mar & Oct 2007-1.mp4 [17:25:25] + container: MPEG-4 (.mp4 and .m4v) [17:25:25] + 64-bit formatting [17:25:25] * video track [17:25:25] + decoder: mpeg2 [17:25:25] + bitrate 8000 kbps [17:25:25] + frame rate: same as source (around 25.000 fps) [17:25:25] + strict anamorphic [17:25:25] + storage dimensions: 720 * 576 -> 720 * 576, crop 0/0/0/0, mod 0 [17:25:25] + pixel aspect ratio: 16 / 15 [17:25:25] + display dimensions: 768 * 576 [17:25:25] + filter [17:25:25] + Decomb (default settings) [17:25:25] + encoder: H.264 (x264) [17:25:25] + options: ref=1:weightp=1:subq=2:rc-lookahead=10:trellis=0:8x8dct=0 [17:25:25] + quality: 20.00 (RF) [17:25:25] * audio track 1 [17:25:25] + decoder: Unknown (AC3) (2.0 ch) (track 1, id 0x8000bd) [17:25:25] + bitrate: 224 kbps, samplerate: 48000 Hz [17:25:25] + mixdown: Stereo [17:25:25] + encoder: AAC (faac) [17:25:25] + bitrate: 160 kbps, samplerate: 48000 Hz [17:25:25] file is MPEG Program Stream [17:25:25] Probing 1 unknown stream [17:25:25] Probe: Found stream mpeg2video. stream id 0xe0-0x0 [17:25:25] reader: first SCR 146 id 0xe0 DTS 17847 [17:25:25] yadif thread started for segment 0 [17:25:25] encx264: encoding with stored aspect 16/15 [17:25:25] encx264: Encoding at constant RF 20.000000 x264 [warning]: --psnr used with psy on: results will be invalid! x264 [warning]: --tune psnr should be used if attempting to benchmark psnr! x264 [info]: using SAR=16/15 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [17:25:25] decomb thread started for segment 0 [17:25:25] yadif thread started for segment 1 [17:25:25] mpeg2: "" (1) at frame 0 time 3600 x264 [info]: profile Main, level 3.0 [17:25:25] decomb thread started for segment 1 [17:25:25] sync: first pts is 3600 [17:54:27] sync: adding 544 ms of silence to audio 0x8000bd start 150537600, next 150488640 [20:05:53] reader: done. 1 scr changes [20:05:54] work: average encoding speed for job is 23.628338 fps [20:05:55] sync: got 227518 frames, 227425 expected [20:05:55] mpeg2 done: 227518 frames [20:05:55] render: lost time: 0 (0 frames) [20:05:55] render: gained time: 0 (0 frames) (0 not accounted for) x264 [info]: frame I:1643 Avg QP:19.66 size: 49896 PSNR Mean Y:43.04 U:49.85 V:49.37 Avg:44.31 Global:43.93 x264 [info]: frame P:130313 Avg QP:22.60 size: 27056 PSNR Mean Y:39.28 U:47.29 V:46.63 Avg:40.66 Global:40.20 x264 [info]: frame B:95561 Avg QP:25.18 size: 14126 PSNR Mean Y:37.23 U:46.74 V:46.00 Avg:38.70 Global:38.33 x264 [info]: consecutive B-frames: 17.2% 79.3% 3.2% 0.3% x264 [info]: mb I I16..4: 25.9% 0.0% 74.1% x264 [info]: mb P I16..4: 15.3% 0.0% 4.0% P16..4: 35.8% 21.4% 18.6% 0.0% 0.0% skip: 4.9% x264 [info]: mb B I16..4: 2.9% 0.0% 0.4% B16..8: 31.1% 15.4% 4.2% direct:27.5% skip:18.4% L0:28.4% L1:37.7% BI:33.9% x264 [info]: coded y,uvDC,uvAC intra: 46.2% 47.4% 8.8% inter: 52.8% 27.4% 1.2% x264 [info]: i16 v,h,dc,p: 31% 29% 30% 9% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 23% 21% 6% 6% 5% 7% 5% 6% x264 [info]: i8c dc,h,v,p: 55% 23% 19% 3% x264 [info]: Weighted P-Frames: Y:14.7% UV:3.4% x264 [info]: SSIM Mean Y:0.9630482 (14.324db) x264 [info]: PSNR Mean Y:38.444 U:47.074 V:46.386 Avg:39.862 Global:39.330 kb/s:4357.77 [20:06:00] mux: track 0, 227517 frames, 4957572210 bytes, 4357.67 kbps, fifo 2048 [20:06:00] mux: track 1, 426624 frames, 182008324 bytes, 159.98 kbps, fifo 4096 [20:06:00] stream: 3877958 good frames, 0 errors (0%) [20:06:00] decomb: deinterlaced 212787 | blended 8090 | unfiltered 6640 | total 227517 [20:06:00] libhb: work result = 0 Encode done! HandBrake has exited.
Hope someone can help
Bob (retired)![]()
Thank you for the response MindBender, I dont have VLC player, but it works with WMP and there is a time start, end
The whole point of the file was to burn it to 25GB blu-ray (along with other files) Moving my entire collection from DVD Vob to MP4
Bluray (my player supports MP4 playback)
I spent today re-doing the large 7.67GB MPEG (twice 3 hours each time) using AVS Video converter, H264 format MP4
(first at 4600 kps, then 3700 kps) the file encoded (3.7 GB)
but there was no thumbnail image, and it failed to play with WMP
I think the problem is that the VOB file is over 4GB in size (as all the ones <4GB encoded played perfectly)
What i will do tommrow is i will split the 7.67GB Mpeg file into 2 or 3 segments (using VideoRedo, or Mpeg2cut2) so that
each segment is less than 4 GB in size
and re-encode each section using HandBrake, and then join/mux them up to the full size
Hopefully that should do trick
Bob (retired)
Showing Live Time in scenes with Vegas Studio 10
By HoosierGuy in forum EditingReplies: 4Last Post: 23rd Mar 2011, 15:01 -
subtitle time codes showing in movie
By jacktheflash in forum MacReplies: 2Last Post: 28th Apr 2010, 23:17 -
video clip not showing the time
By Natalie in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2009, 12:31 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 12:46 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48
