Results 1 to 11 of 11
  1. this might sound strange but i want to play some vdeos on my camera(cybershot).it always shows file error what ever i do.
    i tried to convert it with format factory to mpg with the same specifications as the one made by the camera bot no luck.
    please help
    I think most digital cameras can only play the videos created by the same camera.
  3. is there any way i can make it play.cuz i think the camera can only play a specific format and i dont sony uses a lock on these things
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I've never owned a camera that will accept video that it did not create itself.
  5. is there some software than can encode the video exactly like the camera does or atleast gives all the options
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I've tried that already. See my previous answer above.
  7. i found this program called digital camera studio.but it only works up to cybershot w100 models(mine's w150).is there any way to make it work for me?
  8. is there an enorder/converter that gives me control of the GOP cuz in gspot i get 1 intra frame followed by 2 predictive frames and its not the same with the videos made by the digital camera studio.
  9. You haven't said exactly why you want to view your vids on that tiny screen on your camera. Most people prefer looking at their masterpieces on a larger screen. That's why this forum exists. I have a cybershot and I sure don't want to view my vids on that little screen. OK for a quick look to see if it came out OK then I transfer the vid to the computer for proper rendering to a hard disk, DVD or Blue Ray.
  10. well to use it as a portable video player or something like audio with a solid color as the background
