So after reading a great deal here & there I finally managed to summarise what I feel maybe right for an input that is grainy. To be comprehensive my input has dancing pixels & decreasing crf value increases file size such that its not optimum for me, I have varied values b/w 21-23 but the result still is grainy...I thus desired to use a some de-graining techniques two of which were built in x264cli. Now the gurus here might shed light of whether the generalised solution are appropriate & what other solution they recommend me to fiddle with
Below are quotes from across internet
- If you like a clean picture and don't mind a little bluriness try 1:2. --deblock 1:2
- Temporal is particularly good for videos with what I like to call “dancing dots” or “dancing pixels”. For example, when a surface in the video like a wall (which should look pretty static) is grainy and that grain continually moves/dances around during playback (despite looking ok when paused). The temporal denoiser does a pretty good job of noticing this and denoising these areas while leaving the other stuff that looks fine alone. --vf hqdn3d:2,1,7,7
Further Notes:
The input file has a constant bitrate histogram (bitrateviewer) ~5100kbps
My output with --crf 23 --tune film has a great spectrum of bitrate variation such that its avg value of 2200kbps means nothing, why because the scenes which are grainy lie in the range of 3800-4300kbps while the rest mere ~1800kbps(perfect quality), thus grainy scenes are deliberately increasing file size with no quality gain
Input file is a drama with some fast moving scenes like waving hands, some dance & a little bit of slapping, but not detail hungry scenes like scenery etc. though I would like character face detail & skin tone NOT to be pixelated
Code:Format: Windows Media VideoFormat: VC-1 CodecID: WMV3 Resolution: 1280x720 DAR: 16:9 or 1.778 PAR: 1.000 VideoBitrateMode: VBR ScanType: Progressive AudioCodec: WMA AudioBitrateMode: CBR
Results 1 to 1 of 1
Need advice on x264 presets
By augerpro in forum Video ConversionReplies: 9Last Post: 20th Jun 2012, 17:27 -
x264 Tuning advice
By leghorn in forum Video ConversionReplies: 0Last Post: 12th Dec 2011, 12:39 -
The best way to remove grain?
By FatalX in forum EditingReplies: 6Last Post: 11th Nov 2010, 12:37 -
Playback advice on x264 video
By strontium_99 in forum Software PlayingReplies: 7Last Post: 30th Oct 2010, 07:58 -
Grain Retention Switches for X264
By Soopafresh in forum Video ConversionReplies: 3Last Post: 23rd Jan 2010, 04:48
