I have been ripping dvd's lately and there are multiple episodes on the disks. At first I use handbrake and broke up the episodes by chapter. Now I'm using MakeMKV and then extracting the OGM chapter file and using the time codes to split the files. What I want to know is which program offers better quality rips or are they both the same and how can I get the highest possible quality rip (I'm not concerned about how long it will take as long as it's free).
MakeMKV is faster than any encoder ... handbrake is not a slow one ... because you are just changing the container of the video file(s). Like many newer users you're confusing ripping (ie. just copying and/or repackaging the dvd video and decrypting it) with encoding and encoding compressing it.
However, it's trialware, not free.
You could also try dvdfab hd decrypter, which is free. It doesn't put the video into an mkv container. it just creates a video_ts folder which you can them open with a software player. I've used it many times, and it's the best free tool I know of for keeping up with newer dvd copy protection schemes.
If you want the utmost quality and don't mind paying for all that extra storage you'll need (the obvious advantage of reencoding), just ripping is the way to go. It's way faster and, perhaps more important, way easier. Video encoding is very complex and there's no good way to simplify it. -
Thanks, I think I understand the difference. It's a shame it's trialware. I'll give your suggestion a try once the trial is over.
Using MakeMKV then Handbrake - adivce on creating MKVs
By johnnyturbo3 in forum DVD RippingReplies: 4Last Post: 2nd Aug 2012, 18:46 -
Trying to use MakeMKV
By Humbug in forum Blu-ray RippingReplies: 4Last Post: 7th Nov 2010, 09:14 -
Problem with Makemkv, Handbrake and TSmuxeR, only getting half file!
By Capt_Blackadder in forum Blu-ray RippingReplies: 4Last Post: 19th Jan 2010, 11:30 -
MakeMKV --> Handbrake..They won't play nice with each other
By Popi in forum DVD RippingReplies: 5Last Post: 2nd Dec 2009, 05:30 -
MakeMKV
By magmo in forum DVD RippingReplies: 1Last Post: 10th Nov 2009, 12:59
