Results 1 to 21 of 21
  1. hi to everyone.
    i have big problem now. i buy 1 reciever 1080p full hd for watching hd channel .
    i record some channel but i can't play evrything that i recorded on my pc.
    receiver record in tsv extension file that only play on itself .no media players can show this recorded video on my pc.
    plz help me to resolve this problem.also i change extension file to .ts to play on existing ts players but no softwares can show my recorded video channel on my pc.
    technical info is :
    F:\4(20120812_043007)4(20120812_043007).TSV
    General #1388
    Complete name : F:\4(20120812_043007)4(20120812_043007).TSV
    Format : MPEG-2 Transport
    Format/Family : MPEG-2
    File size : 30.2 MiB
    PlayTime : 1s 840ms
    Bit rate : 138 Mbps
    Video #124B
    Codec : MPEG-2 Video
    PlayTime : 1s 840ms
    Bit rate : 135 Mbps
    Audio #124C
    Codec : MPEG-1 Audio layer 2
    Bit rate : 96 Kbps
    Bit rate mode : CBR
    Channel(s) : 2 channels
    Sampling rate : 48 KHz
    Resolution : 16 bits
    Video0 delay : -571ms
    Writing library : Xing (new)
  2. i also try this software http://mpc-hc.sourceforge.net/ but this software only play audio my captured channel. not play video stream.
    plz somebody help me .
  3. Could you upload a clip for us to take a look at?
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Try AVIDEMUX 2.6
    Claudio
  5. sure ! it is now on uploading in website ..... coming soon i post link for my captured video ! thanks a lot
  6. Originally Posted by Cauptain View Post
    Try AVIDEMUX 2.6
    Claudio
    i also download avidemux 2.6 ,cannot play my captured video !!!!
    i download many software from videohelp ,but no software can't play my captured reciever Video.
  7. it's done ! i upload here manoto1.rar
    i hope so somebody can help me .thanks a lot again !!!!
  8. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    No luck for me. Try various players and scripts.
    Claudio
  9. Originally Posted by Cauptain View Post
    Claudio
    yeah i know u are bad luck because i use many software for decoding my captured video ! maybe another users think this video have problem ! but it have not any problem and can only play in my receiver ! this problem is new for me !
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ProjectX wont touch it either. I get terrible audio but no video.
  11. Banned
    Freedonia
    You need to install MediaInfo and post here what it says about your file. Something I read about TSV on another forum suggests that it is encrypted. Media Info can tell us.
  12. Originally Posted by jman98 View Post
    i download your software and it is result
    General
    Complete name : F:\pvr(20120812_043007)\Manoto 1(20120818_110307)\Manoto 1(20120818_110307).TSV
    Format : MPEG-TS
    File size : 37.3 MiB
    Duration : 1mn 18s
    Overall bit rate : 3 983 Kbps
    Video
    Menu ID : 17650 (0x44F2)
    Format : MPEG Video
    Format version : Version 2
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Codec ID : 2
    Duration : 31s 680ms
    Bit rate mode : Variable
    Bit rate : 3 592 Kbps
    Width : pixel0
    Height : pixel0
    Frame rate : 0.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Stream size : 13.6 MiB (36%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 4
    Duration : 1mn 17s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Sampling rate : 48.0 KHz
    Delay relative to video : -289ms
    Stream size : 1.78 MiB (5%)
    Language : English
    Menu
    Duration : 1mn 18s
    List : 1050 (0x41A) (MPEG Video) / 1250 (0x4E2) (MPEG Audio, English)
    Language : / English
  13. Banned
    Freedonia
    Your file contains no video information. The Width and Height are 0 pixels. This is why you only get audio. You need to tell us what the model number is of the device you are using. My guess is that you either don't actually have the video connected to it or you have it in some kind of mode where it is only recording audio.
  14. Originally Posted by jman98 View Post
    my reciever is hi tech 1080p Full HD !!! my captured video have compeletly video stream ! i say again i can play this video on my reciever without any problem ! but i cant play in my pc ! i think reciever company used self codec that nobody can decode it ! it is my opinion because no software exist that can open it on pc !
  15. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Whats receiver model??
    Claudio
  16. hi-tech 1080p Full HD.
  17. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Go to the receiver forum : http://www.satfriends.com
    Register and post your question, probably encrypted file.
    Claudio
  18. Originally Posted by Cauptain View Post
    Claudio
    thanks, i try this forum also.
  19. nobody answer to me on satfriends.com ! dead forum ! nobody can resolve my problem in videohelp ?
  20. Banned
    Freedonia
    Your device appears to only be sold in the Middle East. We don't have a lot of members from there. We can't be experts on devices that we don't own and use. We've given you the best answers we can considering that none of us who have responded have ever used your device. Your file is either encrypted or the video header is wrong. If it's encrypted we don't know how to decrypt it. If the header is wrong, you will have to find a way to fix it so you can change the height and width values. I suggest that you try to find a program that will let you fix the width and height values in the header of the video file as this is the only solution to your problem that you will be able to do successfully.
    You should be aware that most PVR/DVR devices encrypt what they record and unfortunately it is normal to not be able to play recorded files on a PC.
    Aug 2006
    After changing the file extension to .TS I tried opening the .TSV file with TSDoctor. TSDoctor reports the file is encrypted.
