what is size of GOP in HEVC?????
Results 1 to 15 of 15
MOving you to our video conversion section.
See https://forum.videohelp.com/threads/249602-How-does-GOP-size-affect-recording -
for example, the code for the video foreman.cif.some put it?
(in software HM-6.3.1) -
There is NO *fixed* GOP-size, it all depends on where/how the encoded stream will be viewed.
BTW, are you sure you did mean HEVC?
http://en.wikipedia.org/wiki/High_Efficiency_Video_Coding -
No, sorry, I had no idea there is something called "HM-6.3.1"
Maybe I will try to compile it with MinGW, though.
Anyway, it's hard to believe that either the format itself or a particular encoder would enforce a fixed GOP-size for all types of uses or circumstances
I want to do video foreman.cif with the software hm-6.3.1 coding.Gives the following errors
error: QuadtreeTULog2MaxSize must be 5 or smaller
error: found fewer Reference Picture Set than GOPsize
error: invalid GOP structure -
You need to be much less cryptic and much more clear & detailed to get any kind of meaningful response.
from what i've read hevc doesn't use a fixed gop structure. it's called "adaptive" as it changes on the fly.
@ maryam209 --- how/where did you get the executable form of that encoder?
I've just downloaded its latest git code, but I simply don't know how to compile the damn thing, there are NO detailed instructions for the newbies, and I even am not sure whether the Linux code will be accepted by the MSYS+MinGW environment.
For the curious, here goes a PDF about that surely-pre-alpha software: -
A quick glimpse at the PDF indicates that the encoder doesn't currently support dynamic GOP sizing.
3.1 GOP structure table
Defines the cyclic GOP structure that will be used repeatedly throughout the sequence.
[Help] Gop Structure
By toryang in forum Video ConversionReplies: 17Last Post: 2nd Sep 2012, 09:49 -
Convert to MXF file with closed GOP every GOP?
By Gobblor in forum Video ConversionReplies: 0Last Post: 17th May 2012, 05:27 -
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 16:29 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 13:19 -
How does GOP size affect recording ?
By Serville in forum Capturing and VCRReplies: 11Last Post: 17th Dec 2007, 09:02
