I am fairly new to encoding programs and video files. What program is the fastest and easy way to encode these video files with .srt subtitles added? The final video format will be MKV which I believe is the best. I'm looking for a lite program and will be able to encode these videos with about the same amount of size without sacrificing the audio/video quality.
A bit more information would assist...
What equipment are you playing back the final MKV file?
PC, Media Player (brand and model), Smart TV etc etc
If you are playing it back on a PC all that is necessary is to name the SRT file the same as the video and VLC for example will display the subs. If you want to include ie mux the subs into the MKV then MkvMergeGui will do it in a few minutes.
Lots of variable so we need lots more info..SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If you want to hardcode/burn in subtitles can you use freemake video converter, video to video converter, handbrake, etc. It requires reconversion so you will lose quality but it works on ALL devices then.
Just on a PC using VLC/KMPlayer and Showtime on my PS3. It sometimes annoys me to see the .srt files and it clutters the whole folder. I'll try MKVMergeGui and see what I can find. I'm looking for something like ASFbin program that joins wmv files without re encoding and its fast and easy.
I don't want it to be hard subbed since MKV is naturally soft subs so it makes the encoding easier. I just wanted the default resolution and all other variables to be the same when muxing the srt files in.
Adding .srt to 1080p .mkv NOT WORKING!
By The_WRATH in forum SubtitleReplies: 8Last Post: 11th Apr 2020, 07:06 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
.srt Subtitle in "not DVD" File like mp4, mov or avi
By oldMac in forum ffmpegX general discussionReplies: 2Last Post: 8th Apr 2010, 18:12 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
