The program worked perfectly for years. Noe it consistently crashes stating there is an avisynth error. I have reinstalled the program and have not added any conflicting applications that I know of.
Here is the latest logfile
Video: C:\Users\Brendan\Videos\The Thin Red Line\The Thin Red Line CD01.avi
Info: XviD - 1042 kbps - 576x320 - DAR 1.8 - 25 fps (CFR) - Progressive - 1:22:54 hours - 124353 frames
Audio 1: C:\Users\Brendan\Videos\The Thin Red Line\The Thin Red Line CD01.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 1:22:54 hours (0 ms delay) - Internal
[MediaInfoLib - v0.7.59]
<11/1/2012 5:30:06 PM>
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Users\Brendan\Videos\The Thin Red Line\The Thin Red Line CD01.avi", CacheFolder="C:\Users\Brendan\AppData\Local\Temp", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\Users\Brendan\Videos\The Thin Red Line\The Thin Red Line CD01.avi", CacheFolder="C:\Users\Brendan\AppData\Local\Temp")
Video = Video.ConvertToYV12()
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,2,0,2)
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 2067.6 MB
HCenc Parameters: -ini "C:\Users\Brendan\AppData\Local\Temp\DVD_0_Title_0 1_The Thin Red Line CD01.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Brendan\AppData\Local\Temp\DVD_0_Title_01 _The Thin Red Line CD01_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Brendan\Videos\DVD_0_Title_01_The Thin Red Line CD01.m2v
*LOGFILE C:\Users\Brendan\AppData\Local\Temp\DVD_0_Title_01 _The Thin Red Line CD01.HCenc.log
*MAXBITRATE 9000
*BITRATE 3487
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<11/1/2012 5:50:58 PM>
CHECK LOG FILE <C:\USERS\BRENDAN\VIDEOS\THE THIN RED LINE\DVD_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.5.1
Any help would be greatly appreciated.
You uninstalled and reinstalled I assume? Did you also uninstall the programs that avstodvd is a front end for?
I haven't used it for a while ... I gave up burning dvd video as a colossal pain in the ass and I run linux now so I couldn't run it even if I wanted to burn dvds ... but that solved an upgrade related problem for me once. -
@kennedyb4
1. Uninstall AVStoDVD
2. Uninstall AviSynth
3. Restart your system
4. Re-install AVStoDVD Installer Package, that comes with AviSynth embedded.
Let me know
Bye
ffmpegsource2 error in Avisynth
By fidogenial in forum Newbie / General discussionsReplies: 23Last Post: 16th Jun 2016, 18:58 -
mp3 metadata not consistent from PC to PC
By mattman1968 in forum ComputerReplies: 2Last Post: 29th Jan 2011, 20:57 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 01:44 -
FFmpegSource2 error in Avisynth
By fidogenial in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 17:51 -
meGUI - AVISynth Error!
By th3obr0 in forum Video ConversionReplies: 2Last Post: 27th Jan 2009, 21:20
