I'm trying to compare a CFR and VFR encode side by side, but I can't get them to sync properly. Directshow doesn't work, it screws up during seeking.
Is there a way to get Avisynth to read internal timecodes and open it up frame-accurately?
	Not quite - because the VFR version has fewer frames and avisynth is CFR only
 But you can use FFVideoSource() with FFInfo() and it will show the CFR and VFR times overlaid so you can compare. You might compare in different tabs in avspmod for example. Seeking should be frame accurate with ffms2 for most types of files, but you can add seekmode=0, threads=1 with FFVideoSource() for extra security (slower)
	Yes but can it include the D frames so the sync matches with the CFR version? Directshowsource already does this, but it's not frame accurate especially when seeking. FFVideosource opens the video without regard for D frames.Not quite - because the VFR version has fewer frames and avisynth is CFR only
 Okay, how do I do this? Here is my original scriptBut you can use FFVideoSource() with FFInfo() and it will show the CFR and VFR times overlaid so you can compare.
 Code:a=directshowsource("C:\VFR.mkv") b=directshowsource("C:\CFR.mkv") stackhorizontal(a,b)
	There are no duplicate frames with ffms2 and it's frame accurate - I was suggesting to match by timecode using ffinfo()
 You can use DSS2() if you want frame accuracy with directshow duplicates
	Oh right I should've mentioned that what I'm comparing are two videos from different sources, one from DVD one from BD so the frame orientation is not identical to the BD but close enough to compare side-by-side in real time. There's about a 2-second longer delay at the beginning of the DVD which is easily dealt with trim.There are no duplicate frames with ffms2 and it's frame accurate - I was suggesting to match by timecode using ffinfo()
 Also, how do I extract timecodes from MKV? I know how to do it with MP4. And if I had the times.txt, you're saying FFINFO would sync the videos together? You lost me a bit on the last post.
 Directshow's gonna desync while seeking anyways, will it not?You can use DSS2() if you want frame accuracy with directshow duplicates
	You can use ffvideosource to extract timecodes (flv, mkv, mp4 any container)
 eg.
 FFVideoSource("movie.mkv", timecodes="movie_timecodes_v2.txt")
 For FFInfo, it overlays CFR and VFR times so you can match them up to the correct frame
 Try this and you will see what I mean
 FFVideoSource("video.mkv")
 FFInfo()
 dss2 is frame accurate when seeking; directshowsource() isn'tDirectshow's gonna desync while seeking anyways, will it not?You can use DSS2() if you want frame accuracy with directshow duplicates
	Is the VFR video actually VFR, or is it CFR with duplicate frames or with some frames which last for what would normally be the duration for 2 frames etc? If it's the latter, by telling ffms2 to convert the frame rate to the original frame rate you should be able to effectively get it to "fill in" the duplicate/missing frames. For example, 23.976fps:
 FFVideoSource("E:\video.mkv", fpsnum=24000, fpsden=1001)
 If you're using DirectShowSource:
 DirectShowSource("E:\video.mkv", fps=25, convertfps=true)
 When using AVISynth to convert VFR video, you can probably convert it as though it's CFR, extract the time codes from the source, then use the extracted timecodes when remuxing the encoded version to match the audio sync. But of course that relies on both the source and the encode having the same number of frames. I doubt you'd have much luck trying to sync two different videos that way. I've not done it much myself but MKVCleaver will extract timecodes from MKV files and of course MKVMergeGUI will let you use those timecodes when muxing.
	Thanks PDR, DSS2 worked perfectly. I will use this from now on.
 I did FFInfo and what it showed confuses me. Scrolling all the way to the middle the VFR is about 1-2 minutes behind the CFR time as reported by FFInfo but all the way at the end, it's all matched up. The VFR has 33% less frames than the CFR so I expected it to get 10-20 minutes behind at the very end. What is this reporting? The seeking offset of Directshow?
 hello_hello, the video was VFR but I wanted it to be opened with the D frames included so I can align it perfectly with the CFR video for a comparison.
 In this particular department, it's great to have so many choices. I usually hate endless choices.
  Avisynth script help. VFR & timecodesBy Legiit in forum EditingReplies: 5Last Post: 28th Jun 2012, 13:06
  Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issueBy kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 01:54
  Opening a .MOV in AVISynthBy sphinx99 in forum Video ConversionReplies: 4Last Post: 17th Aug 2011, 09:06
  Cause of A/V sync and how recognize when a video has VFR and audio has VBR?By Stb1990 in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2010, 21:05
  HDTV to DVD using DGIndex/AviSynth losing framesBy gadgetguy in forum Video ConversionReplies: 13Last Post: 3rd Sep 2008, 17:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
