Most movies are larger than the 4.7 Gb allowed on most DVD's
How can I overcome this problem?
Results 1 to 19 of 19
Hang on a bit. I think I didn't make my self completely clear. I'm wanting to burn full length movies from my HDD to a DVD.
Your response begs these questions...
How did you get the movies to your HDD in the first place?
What format are they?
Normally, DVD movies exceeding 4.7Gb can be shrunk with DVDShrink, even if the files are on HDD. -
Are these movies MKVs or MP4s? If so you can split them using MKVMergeGUI for MKVs (probably YAMB for MP4) and then burn the split files onto two blank DVD5 discs. You can re-join them later if need be.
Short of that, if you want to shrink the video files you'll probably have to re-encode either the audio, video, or both.
If you've got a lot of files to burn, you might consider doing yourself a favour and investing in a Bluray burner. -
There's your problem. Use a GOOD ripper + shrinker + burner combination (already been mentioned: DVDFabDecrypter & DVDShrink & ImgBurn).
Scott -
DVD Shrink works on fully authored DVD images. You need to author to DVD9 VIDEO_TS structure first, then use DVD Shrink.
@ramosis,
You don't say which models yours is, but the VideoMate Vista TT750F (for example) records DVB+Analog as MPEG2 Video & MP2 audio. If yours is like this, you will need to re-encode your audio to AC3 for it to be both NTSC-DVD-compliant and bitrate efficient. And you should only use the 720x480 resolution (assuming you ARE in NTSC-land).
Once you have a 720x480 (that's MP@ML MPEG2) video and AC3 audio (~128-256kbps @ 48kHz), your clips SHOULD be DVD-compliant, and then you can use a number of good apps to AUTHOR it to a true DVD folder structure (hopefully without re-encoding). Then, if it still happens to be over 4.37GB, you use something like DVDShrink or DVDRebuilder on the AUTHORED Video_TS folder and shrink it down to under 4.37GB (which DOES re-encode, but you can't help that) and you will be ready to burn with ImgBurn.
BTW, it helps greatly if you were more clear and detailed from the beginning about what you had and how you did things and what you wanted in the end. Then we can understand more quickly and help more efficiently. Otherwise, it's often "back to the drawing board".
edit: if you are using AVS2DVD, you should be able to re-encode both the audio+video to DVD-compliant assets as well as keeping them under the appropriate bitrate limits, which bypasses the need for DVDShrink/DVDRebuilder. -
DVD Shrink is only useful if you only need to shrink by 10 percent or so, or if you need to shrink very quickly. Otherwise you will get better quality if you re-encode the source to DVD compliant specs.
My apologies for not giving more detailed information. Let me start from the beginning and I hope you will indulge me.
First of I'm on Win XP Pro 32bit
I'm using Video Mate M1F
Basically what I'm trying to do is copy videos on my hard drive ( which I have recorded directly from the TV) onto DVD.
Most videos are larger than 4.7 Gb and I need to 'compress' them.
Software that I have includes, Image Burn, Avidemux, AVStoDVD and DVD Shrink.
Now do I have the correct software to do the job? If not what do I need?
Many Thanks for your patience and interest in my problem. -
This still isn't clear. Do you want to make a movie DVD that will play in an DVD player? Video that works in a DVD player must conform to DVD standards (MPEG 2, bitrate and resolution restrictions, etc). Or do you just want to burn data discs with your video files on them? Like you can burn a bunch of Word documents onto a DVD. Obviously, no DVD player knows what to do with DOC files. That would simply be for backup or transfer purposes.
Help - How To De-compress SWF Video Files
By rckowal in forum Video ConversionReplies: 5Last Post: 3rd Jan 2011, 15:37 -
How to compress MPEG4 files for emailing?
By robinh in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2010, 16:00 -
ACVHD files get compress again in rendering?
By yogart in forum Newbie / General discussionsReplies: 11Last Post: 1st Oct 2010, 11:54 -
How to compress files?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2010, 12:42 -
Compress some files
By alintatoc in forum ComputerReplies: 5Last Post: 24th Feb 2009, 05:14
