Hi All,
I want to use a transcoding effect which can be seen on film leader countdowns. Is this possible with some help from AVS Script or Virtualdub plugins ( i've used many virtualdub pluggins , but i havent heard a proper one for this purpose) ?
Old , long and not easy way: i can create a background picture and later i can create some semi-transperant "pie chart" or "radar beam scan" looking 25 photos and make it like a "image sequential" video.
Thanks.
Describe what you want more clearly. Do you want it exactly like a film leader countdown?
Something like this?
http://archive.org/details/CincinnatusSMPTEFilmLeader_Test_
Most NLE's will have a film leader countdown if you want a "clean" one -
Yes same as this one and also other effects that i can use while i join other video segments. You are right most NLE's have but i do not want to pay or used a cracked commercial software.
I am looking for a freeware alternative. Otherwise i will something in old fashion way which will take some time. -
It shouldn't take much time at all to google up an example, then replicate the elements and run it as a PNG still sequence.
Any old raster graphics editor will do it.
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 17:01 -
Autogk Virtualdub AVS question.
By meneedit in forum Video ConversionReplies: 0Last Post: 9th Feb 2012, 04:31 -
AviSynth & VirtualDub - Comfortable ways to create avs-files?
By klischee in forum EditingReplies: 7Last Post: 28th Oct 2010, 16:20 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 10:53 -
Error with AVS and VirtualDub
By megakoolkid in forum Video ConversionReplies: 11Last Post: 23rd Aug 2008, 14:16
