I am going to write code using the MPC web interface to control 100% of all my TV shows. My problem is, if I enable it on MPC X version it will also enable the web interface on X+1 version... It even does this for MPC vs MPC HC. So even if I have 10 versions of MPC they will all use the same settings....
I do not want to dump MPC as my default video player. Can I somehow fix this or am I SOL?
sounds good. How do i set this up?
edit: Options > Player > "other" section, "store settings to .ini file -
Using the portable version?
http://www.portablefreeware.com/index.php?id=2054
Actually copying the portable to a new folder is probably a good idea, so that multiple instances
don't share the same .ini -
well using MPC solved my settings issue...
But I cant seem to access the mpc playlist from the web interface (apparently its a limitation of MPC). I am also having problems with the seek bar using MPC with the web interface (but if I cant access the playlist, the seekbar problems are irrelevant). I may try the VLC web interface (just learned today it exists). If that fails I may look into mpc source code (but im not a c++ programmer)
MPC-HC settings?
By Hoser Rob in forum Software PlayingReplies: 4Last Post: 22nd Jan 2012, 10:51 -
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 07:51 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 11:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41 -
some general MPC settings questions
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 08:28
