would anybody be able to assist me in using tivtc on my anime dvd source? I'm using meGUI and the video analysis tool is terrible. The option it gives me causing ghosting and theres still a lot of interlacing. I dont want to deinterlace it wrong. Best results came from tomsmocomp, but i dont care for that deinterlacer. Can anybody help?![]()
That video was converted from 25p to 29.97i with field blending. The best result will come from converting back to 25p. That can be done with Yadif(mode=1, order=1).SRestore(). That will eliminate a lot of the blending and leave you with fairly smooth pans. I don't think you can do that in Megui though. Attached is a 25p sample with QTGMC(preset="fast").SRestore().
The video could also use a lot of other filtering. Deblocking, Deringing, etc.Last edited by jagabo; 31st Oct 2012 at 16:39.
if u still have the script u used for this sample, would u mind posting the whole thing, or sending it to me somehow?
deinterlacing
By encodingmonkey in forum ffmpegX general discussionReplies: 5Last Post: 25th Jul 2012, 14:27 -
deinterlacing
By encodingmonkey in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2012, 19:14 -
A few deinterlacing questions...
By SBPP in forum Newbie / General discussionsReplies: 4Last Post: 16th Nov 2009, 23:42 -
What is going on with Deinterlacing?!?!
By jieve in forum DVD RippingReplies: 30Last Post: 9th Aug 2009, 15:23 -
OS X Deinterlacing
By ggp759 in forum MacReplies: 4Last Post: 22nd May 2008, 16:37
