Turn off transparency effects in Win7 and the UI is very close in speed to Win8. I ran a few x264 encoding benchmarks when I had Win7 and Win8 installed on the same computer. Encoding under Win8 was a tiny bit faster. Less than a 1 percent difference if I remember correctly. One thing to keep in mind is that Metro applications don't shut down when you close them. They just minimize. So they "restart" faster.
Results 31 to 36 of 36
It sounds to me like this is falling on the other side of the divide between consumer / hobbyist grade and professional grade apps. The more commonly used apps featured and discussed here more than cover my needs -- now, or as far out as I can see at the moment. And there's no good reason why I can't continue using them for a long time, under Win-7 or even XP. (Even if I'm forced to avoid the latest gen hardware to continue doing so.)
Take a poll here on how many of us are still working with DVD video and the tools used for that, vs. Blu-Ray video format, and I suspect that it may prove my point. 2K, 4K, and beyond I'm happy to leave to Peter Jackson and James Cameron. Doubt I'll be needing that anytime soon.
How easy is it to do that ? I've really been tempted, almost every day. The distracting Aero eye candy and transparency adds very little that is truly useful. Your mouse wanders a bit, and you find that something that had the desktop has "disappeared", or switches to something else. 'Where am I now ?' Oh, right, move the mouse back. The Previews and faster snap-back of minimized items is a 50-50 tradeoff.Originally Posted by jagaboWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
Right-click My Computer -> Advanced system settings. That brings up System Properties -> Advanced -> Performance. (Visual Effects, etc.)
Select Settings -> Visual Effects. Then select "Adjust for best performance". That will turn Aero off entirely. Or use Custom and turn off options individually.
Anyway, I intend using Win7 for a long time. I'm used to it, my programs work fine, and I like it as well.Pull! Bang! Darn! -
Transparency effects for window borders can be controlled separately by right clicking on the Desktop, selecting Personalize, clicking on Window Color, then disabling the Enable Transparency option.
I'd like to second the thank you from Seeker 47.
I'm running Vista and wouldn't mind turning off aero to boost performance a touch.
However it is set to let Windows choose best appearance and everything is selected. If I choose best performance everything is deselected.
Which is exactly is "aero" in the list? I don't know that I want to turn off ALL of the graphical niceties of Aero just a few to save on system resources.
Is there a list of which ones use up the most power? (please note I only have 2gb ram and thats all I can put on my motherboard).
Thanks.
Edit - just saw jagabos post and I am on (correction I'm running WINDOWS VISTA BASIC but Aero is not selected at all) WINDOWS BASIC not AERO after all - looks like I'm not running Aero afterall. Thanks everyone
Windows Media Center .wtv 720p (60fps) to Xvid AVI (24fps) in Windows 7
By cg-realms in forum Video ConversionReplies: 0Last Post: 7th Jan 2010, 19:47 -
Windows 2003 or Windows 2008 based on my server specs & needs...
By retroborg in forum ComputerReplies: 18Last Post: 23rd Jun 2009, 07:29 -
Remain Bit rate or increase when convert to dvd?
By sychern in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 19:26 -
I want to cut the audio from the video, only remain video?
By awaisuk in forum EditingReplies: 2Last Post: 20th Nov 2007, 08:17 -
How similar is Windows Server 2008 to Windows Vista?
By davidsama in forum ComputerReplies: 6Last Post: 12th Nov 2007, 11:25
