So I really want to rip blu ray films on to my laptop, because I like to use those films in sony vegas and edit them. You know the typical amateur vids you see.I was looking for external blue ray writers and found this one - http://www.wiseguys.co.nz/samsung-se-506ab-external-blu-ray-writer-185075.
But I am not sure if I should even buy it. Does your laptop need extra power or uhhh any other special gadgets to allow it to copy blu-rays? Does a blu ray writer ever mean it will let you copy the files on to the computer? I'm kind of confused. Because I see that you need a blu ray DRIVE to copy the files on to your computer but is it the same as a Blu ray WRITER?
As you can probably tell I am an idiot when it comes to computer stuff, but any help is appreciated.
No, you don't need any special gadgets. And yes you can copy most blu-ray with a decrypter like anydvdhd.
But it wont be that simple to edit blu-rays. You might have to convert the blu-ray to avchd to be able to import it correctly in vegas for example. And editing 1080p video requires a lot from your computer...or it will take ages to edit and export. -
Yeah, if you want to edit/render 1080p you're basically talking gaming machine cpu and ram.
Available Blu-ray drive with SONY VAIO & Apple Mcbook laptops
By vikas.babu in forum MacReplies: 0Last Post: 22nd Mar 2011, 05:52 -
Play full blu-ray movies on ps-3 from hard drive
By jim49 in forum Software PlayingReplies: 2Last Post: 7th Apr 2010, 19:54 -
Blue ray Mkv movies
By mikethemadmonk in forum Blu-ray RippingReplies: 1Last Post: 19th Jan 2010, 04:22 -
Very new newbie, Blue Ray drive and now movies are grainy
By tpmrcp in forum Software PlayingReplies: 3Last Post: 11th Nov 2008, 08:33 -
Blu-ray ripped files to hard drive in Folders not un ISO Image
By judgmentday in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2008, 15:26
