I have problems playing 1080 movies on my computer. It looks like this.
Codec: H264-MPeg AVC
Reoslution 1920x1080
Frame Rate:50
My computer:
Intel i5 3.30GHz (4CPU)
Memory: 8GB
Does anybody have any idea what's causing this? I don't have any problems with other resolutions or formats. Only mkv/ts/mp4 with resolution of 1080 gives me this output. 720's also look fine.
"Against All Odds"
The whole video looks like that or just occasionally?
Try switching the output renderer in VLC. Tools -> Preferences -> Video -> Output... After changing to another renderer Save, exit VLC, and restart it.
Try Windows GDI first. That will isolate whether the problem is in the decoding of the video or the graphics cards processing of video. -
THe whole video looks like that, from start to finish.
I tried windows GDI but it still looks the same. Currently trying the others. I will update if/when i have a solution. ANy other suggestions are highly welcome, this sucks...
And so far it only happens with 1920x1080 videos. 720 videos (even with higher framerate) all look allright..."Against All Odds" -
Try turning off GPU accelerated decoding? It's in the Input & Codecs section. This looks like a graphics driver bug. Have you updated to the latest WHQL certified driver for your graphics card?
Looks like your video card is outputting 256 colors instead of 16 million at that resolution.Sounds like a video card driver issue that jagabo mentioned.
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 09:45 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43 -
1080p movies are to heavy for my PC?
By fussgen in forum Newbie / General discussionsReplies: 17Last Post: 30th Aug 2009, 23:20
