Hi!
I have converted a movie with two languages and one subtitle(SVCD Subtitles). Now I have two kind of mpeg files in my Movie-Folder. One normal muxed mpeg and one Muxedsub mpeg or so. Now I burned with CDRWin using "Load Cuesheet" both types but I never can see subtitles. What do I have to do to integrate subtitles in this movie!
Thanx for your help!!!
Dobrovolski
Hi,
Did you check your player brand in the vcdhelp dvd players list to see if your player supports subtitles?
or do you just watch the svcd at your pc?
in the latter case you wont see subtitles
If you select the option 'permanent subtitles' in DVDSVCD all the subtitles are 'burned' into the mpeg (unselectable but you will have them and it works at all players supporting SVCD)
gr,
Bart.
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48
