Hey, guys,
I wonder if you can help me out here, Iīm in one hell of a problem.
A few minutes ago I inserted a pen drive into my old computer's USB and the computer froze.
I pressed the reset button hoping to reboot it and now it wonīt restart.
When I switch on the computer, the screen appears with the P5K SE ASUS screen.
Then I get this message:
USB device over current detected!!
System will shut down in 15 seconds.
And the computer switches off by itself.
Windows XP home edition
P5K SE motherboard
3-4 gigs ram
Ge force board, canīt remember the series
Is there a way to remedy this?
I have tried disconnecting all USB devices but the problem persists.
Help.![]()
"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
When you play it forward, it installs windows." -
Google turned up this. They found a solution:http://www.tomshardware.com/forum/314200-30-device-current-status-detected-shut-seconds
Correct. One of the USB ports' contacts is physically damaged, creating a short circuit. Shine a flashlight into your USB ports and check that none of the metal contacts inside are touching each other. If a contact is shorting another, you can try to play the game of using a small tool to bend the contacts away from each other, or disconnect the cable inside your PC that connects that port to a USB plug-in port (called a "header") on your motherboard. IF you feel you don't want to do perform that fix, take the PC to a local shop (NOT the Geek Squad !! They don't know crap).
Smrpix post is correct and unplugging the suspected cable to the Motherboard header is the easiest way to determine. The most common problem of overcurrent, or any USB problem for that matter, is usually bad device, plug or cable. Most of the time it's the pins inside that get bent and short to each other which could have happened when the pen drive was inserted.
If that doesn't work make sure that you unplug the other USB I/O including the keyboard and mouse if they are USB also. You wont get very far without them but at least you may get past the 15 seconds letting you know one of them is bad. There may also be other USB products and a real killer is the USB card reader for memory cards such as SD, SM, MMC, etc. Those pins get bent very easily.
Hopefully it's just the pen drive socket and unplgging the cablefrom the header will solve.
OOps soory, you beat me to it Sanlyn. I also agree with your "NOT the....." comment LOL.Last edited by Budman1; 28th Oct 2012 at 21:26. Reason: late post. already correctly answered.
Oops, forgot: UNPLUG the power cord. Turn just turn off the PC, unplug it from AC power. As long as your 'puter is connected to A.C., the motherboard is till receiving current.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Easycap DC60 busted?
By muffinman123 in forum Capturing and VCRReplies: 0Last Post: 18th Jun 2012, 15:56 -
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Guy is busted for modding videogame consoles
By ps2daddy in forum Off topicReplies: 12Last Post: 29th Aug 2009, 00:25
