  1. Hello,
    After installing MPCHC, i installed LAV filters & madVR by clicking install.bat from zip folder, but when i try to select madVR in output it shows unavailable, can anyone please suggest how to solve this ?
    System: Windows 7,i5,64 Bit, 8GB RAM, 1GB RADEON Graphics.
    Regards
    Skorpinok
  2. What version of MPC-HC are you using? madVR is 32-bit only, if you're using the 64-bit version of MPC-HC/LAV it's not going to work.
    Mar 2011
    Nova Scotia, Canada
    This is so funny. It's either guys saying you don't need 3rd party products for mpc-hc or stuff like this to make it work properly. Or not.
    It's just another video program that makes it look simple on the surface but dumps you straight into video geek stuff beyond that. The settings are pitiful.
    If you just removed all those crap codecs and filters, which can really cause system instability, and installed vlc and smplayer you'd be able to play pretty much any video between them. And they don't need codecs.
  4. Nobody needs external filters for MPC-HC either, but I guess if you've only ever used VLC player and others you wouldn't know anything about getting better results anyhow.
    What exactly is a crap codec anyhow? If you gave more indication that you actually knew what you were talking about I might take you more seriously. And what exactly does any of this have to do with the OP's question?
