I have used various tools to extract the audio from a movie file I have. Every time I do it, the audio comes out VERY quiet. However, whenever I play the movie in KMP player or VLC, it sounds nice and loud?
Am I doing something wrong? Is KMP or VLC applying massive amplitude? Seems very unlikely..
Results 1 to 14 of 14
How do you extract it? Just demuxing with demultiplexers or converting to wav,mp3,etc?
What kind of of audio? AC3? -
yes, I am not very familiar with the settings I need to apply, but I am extracting to .wav, not sure what type of audio it is in the movie. Its Xvid.
have tried with audiograbber, filefactory.. always the same result, comes out VERY quiet.
Use mediainfo to check what kind of audio.
And what do you convert it to wav with?
I would just try demux the audio with for example Pazera Free Audio Extractor. Or convert to wav and boost the volume in the converter. I think pazera can do that also. -
Thanks for replies.
I am in Panzera now but I cant see any option to demux? I tried exporting to 300% volume but its STILL quiet and just has loads of hiss
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 11mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 120 MiB (18%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Title : Audio
Writing library : LAME3.96r
Encoding settings : -m j -V 4 -q 7 -lowpass 17.5 -b 128 -
Under output format choose: Try extract original audio stream.
aha, I think we are getting closer to solving. I've rarely heard about a 48k mp3?!
Error # 1
Date & Time: 28/10/2012 / 15:52:45
ExitCode: 1
[mpeg4 @ 0x2de3e0] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'L:\download\Gomorra.2008[DVDrip]XviD[Ita].kitrinipapia.avi':
Duration: 02:11:24.72, start: 0.000000, bitrate: 727 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x328 [PAR 1:1 DAR 90:41], 25 tbr, 25 tbn, 25 tbc
Metadata:
strn : Video
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Metadata:
strn : Audio
-acodec copy and -vol are incompatible (frames are not decoded) -
got you stumped as well? ;( I will try and find another copy of the movie file which hasn't been ripped so confusingly.
I don't know about KMP but I'm pretty sure VLC's maximum audio volume is 200%.
48k MP3 is perfectly normal if it was encoded using a 48k source, which most soundtrack audio is.
Try using VirtualDubMod to extract the MP3 audio. When you've opened the AVI, use the Streams/Streams List menu, then the Demux button in the Window which opens.
MP3 audio can have it's playback volume adjusted without re-encoding. MP3Gain will do it. By default, MP3Gain has it's normalizing function disabled so you'll need to go into it's settings and enable the normalising features first. Or try MP3DirectCut. It'll normalise MP3 audio too. -
CURSES! I REVEALED MY ILLEGALITY THROUGH MY OWN IGNORANCE!!
Apologies everyone, and thanks for all the helpful advice.
Warez, thats a old school word!!! You been strutting on this information super high way since back in the day right?
Apologies.
Blu ray extracting/transcoding for a movie file. Help appreciated !!
By THUGGY1111 in forum Video ConversionReplies: 15Last Post: 24th May 2011, 14:32 -
By THUGGY1111 in forum Blu-ray RippingReplies: 1Last Post: 17th May 2011, 03:52 -
Extracting subtitles from a bluray movie on mac
By BIFFtheSTIFF in forum MacReplies: 4Last Post: 15th Jan 2011, 05:18 -
Help extracting softsub from a .mkv movie file.
By Danilux in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2008, 00:18 -
Problem at Adobe Premier 6.0 : Extracting .MOV movie
By chineloninja in forum EditingReplies: 1Last Post: 8th Jul 2008, 19:03
