Results 1 to 1 of 1
  1. Hi
    I have seen in vdub capturing menu "Filter chain", but I never put to much attention to it. Today i tried to capture from my vcr to the pc card and in under the menu selected enable filters and then there is skip 24 rgb conf like on the picture i captured the file while enabling the MSU noise reduction filter in vdub ( how by the way can work real time because it uses gpu) and read it with mediainfo it says yuv video but i cannot notice any chroma or grain noise.
    My question is what vdub do when you select the filter chain menu and enable in the list you chose for example very fast filters and apply them, does it engage them when capturing and if you chose skip 24 rgb conv does it not do any color conv while capturing?
    Format : AVI
    File size : 485 MiB
    Duration : 1mn 18s
    Overall bit rate : 52.0 Mbps
    Video
    Format : Lagarith
    Codec ID : LAGS
    Duration : 1mn 18s
    Bit rate : 50.5 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 4.872
    Stream size : 471 MiB (97%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 1mn 18s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 14.3 MiB (3%)
    Interleave, duration : 27 ms (0.67 video frame)
    Interleave, preload duration : 106 ms
