On a whim today, I decided to try the TMPGEnc MPEG Smart Renderer software (currently known as TMPGEnc MPEG Editor 3). I was very surprised to find that scrubbing the video at any speed other than normal playback resulted in a very macro-blocky mess. Is there a setting that I have misconfigured or is this normal behavior? If so I am surprised. Both VideoReDo & MPEG Video Wizard have very clean playback at all speeds. Please let me know your experiences with this. Thanks.
- Smells_Like_Feet![]()
TMPGenc Editor is an editor. Other than applying a few special effects like dissolves, cutting and joining is its major task. The problem depends on what you're trying to do and what you used for input. Without more info, there's not much anyone could say.
And the source file was .... ?
Give specs.Want my help? Ask here! (not via PM!)
I tried both a dvd ifo for input (selecting the main title for the video) and previously edited MPEG 2 videos (source again was a commercial NTSC dvd). Nothing exotic tried at all. Again, I was just surprised that the FF and FR both caused the video display to be terrible (just macroblocking).
Here is an MediaInfo report of a file tried:
Format : MPEG-PS
File size : 15.7 MiB
Duration : 27s 840ms
Overall bit rate : 4 731 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Duration : 27s 811ms
Bit rate mode : Variable
Bit rate : 4 445 Kbps
Maximum bit rate : 9 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.429
Stream size : 14.7 MiB (94%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 653 KiB (4%)
Text
ID : 224 (0xE0)-CC3
Format : EIA-608
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Thanks for the help. -
Nevermind. I figured out that it was the default configuration of my Shuttle Pro. Apparently if you use <Ctrl>+2, <Ctrl>+3 ... it causes the macro-blocking. using straight keyboard shortcuts doesn't seem to cause it. Sorry for the false alarm.
Time Scrubbing
By stringcheesy in forum DVD RippingReplies: 5Last Post: 11th Sep 2011, 12:46 -
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
Poor picture from my tv to my dvd recorder - please help!
By mariabkbcards in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Oct 2009, 21:44 -
avi to dvd picture poor quality
By dwilson in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2009, 08:10 -
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00
