Hello ,
how to stick subtitles to a video file so that i can watch them on my HD TV ?
Use a software that can burn in subtitles like freemake video converter, handbrake, xvid4psp, video to video converter.
Or, if your TV supports it, place a subtitle file together with the video and with the same name as the video.
If you want hardsubbed video, there's no way around it - you have to re-encode the entire video.
What model TV are you using? I'd wonder if it does indeed support separate-file subtitles, or subtitles muxed into a video container. If not, then your only option is hardsubbing.If cameras add ten pounds, why would people want to eat them? -
For avi divx/xvid files try aviaddxsubs. I have read that it works on Sony TVs.
Hmm. Does your manual mention anything about subtitle support? I've found a manual - UK version, and I'm not 100% sure it's to the same TV - but it doesn't mention anything about subtitle support at all.
Some comments on the web seem to indicate it should play subtitles if you have a .srt subtitle file with the same name as your video (movie.avi, movie.srt), and press the Subtitle button on the remote.
Also, if you do have AVI, do try AVIAddXSubs, as Baldrick mentions. I can't guarantee the TV will support it, though, but it shouldn't hurt to try.
Switchable subtitles (not hardsubs) that are stored within a video file (=container). If you can switch the subtitles on and off while watching the video on a PC, for example.If cameras add ten pounds, why would people want to eat them?
How to stick subtitle and Watermark to mkv videos without re-Encode
By skydl2011 in forum SubtitleReplies: 9Last Post: 6th Sep 2011, 03:10 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
dvp5992/37 - USB memory stick movie file size questions........
By tracnet in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 16:58 -
File wont play from memory stick but will from disc
By muay in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Jan 2011, 08:11 -
M2TS file plays from PC to Xbox no problem but will not play from USB stick
By FuzzyReets in forum Video Streaming DownloadingReplies: 3Last Post: 6th Nov 2010, 08:31
