  1. Hi guys i need a subtitle filter for VirtualDub 1.10.1 for windows 7 64 bit
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Not sure that comes in 64 bit. You can however install the 32 bit Virtualdub along side the 64 bit one and then use DirectVobsub or the subtiler.vdf filter. If you install directvobsub, just go to the folder and copy VSfilter.dll and paste to the Virtualdub plugins folder (I believe evrrything goes in Plugins32 folder now in Virtualdub 1.10.0 ). Then RENAME it to VSfilter.vdf and you will have the "textsub" filter now. The subtitler.vdf also goes in the plugins (plugins32 if latest Virtualdub. There is no plugins folder)
    Any reason you need to use Virtualdub 64 bit instead of 32 bit? 64 bit Virtualdub suffers from lack of codecs and filters available and makes it kind of hampered.
  3. And there's no significant speed advantage in using 64 bit VirtualDub.
