VOB2MPG v3.0 PRO seems not to be working under
windows 8 pro.
Will there be a solution to this problem in the near future ??
Greetings
Paul
Weird ! : I went to : C > VOB2MPG PRO > VOB2MPG demo
Then, I was asked for the registration by internet ( I have a registered version ), and
after some obvious steps I got the program working
Weird, because clicking the programs Icon in the first place,
did not work.
I am a happy man
( Windows 8 Pro ) -
I have been using vob2mpg pro on windows vista with no problem. I just upgraded to a new computer with windows 8.
I have my serial number but not the location to download it again.
However I have tried to get the Freeware version to work, with no success under windows 8 64 bit.
Peter -
Vob2Mpeg is only partially working for me under Windows 8. I set the program to run as administrator (right click on the executable file, then-->Properties-->Compatibility and put a check mark in the box to always run the program as an administrator).
After doing this, the IFO mode works perfectly well under Win 8. The Vobset mode won't even start to process anything. I'm using the free version. -
For all those with the same problem: go to the following link:
http://www.svcd2dvd.com/VOB2MPG/default.aspx, go to registered user,put in the email address that u used for the registration and u will get your license number and a link to down load VOB2MPG 3.0 Pro
VOB2MPG 3.0 Pro runs under windows 8
Peter -
I must make a correction: I can now open the program under windows 8 but like the others it will not process the files it did process under Vista.
Crissy boy, can you comment?
VOB2MPG PRO v3 - Windows 7 Problem
By xtekm in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 1st Apr 2012, 10:00 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
VOB2MPG PRO command line not processing in 64bit Windows 7
By BJTHEDJ in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 6th Dec 2010, 15:53 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53
