I'm trying to use Subtitle Edit (33beta2; also tried stable 3.2.8) to convert idx/sub subtitles to srt using the command line:
andCode:SubtitleEdit.exe /convert "h:\TestClips&Co\DVDs\ElephantsDream\TITLE_1_0_en.sub" DVDSubtitle /outputfolder:"d:\" /fps:25
but I always end up with:Code:SubtitleEdit.exe /convert "h:\TestClips&Co\DVDs\ElephantsDream\TITLE_1_0_en.sub" SubRip /outputfolder:"d:\" /fps:25
File is handled properly if I use the GUI, does anyone know what I'm doing wrong?Code:Subtitle Edit 3.3 ßeta 2 - Batch converter - Syntax: SubtitleEdit /convert <pattern> <name-of-format-without-spaces> [/offset:hh:mm:ss:msec] [/encoding:<encoding name>] [/fps:<frame rate>] [/inputfolder:<input folder>] [/outputfolder:<output folder>] example: SubtitleEdit /convert *.srt sami list available formats: SubtitleEdit /convert /list 1: h:\TestClips&Co\DVDs\ElephantsDream\TITLE_1_0_en.sub - input file format unknown!
Cu Selur
Ps.: I attached the subtitles, for those who want to look at them.
Hi Selur!
Sorry, SE does not support OCR'ing via command line.
Also, I'm not sure it's a good idea to add ocr to command line as ocr often requires manual corrections and has more options than normal converting from one text based format to another text based format (of which SE has about 130 of now) -
Thanks for clearing that up!
Cu Selur
Ps.: I know that's normally not recommend to do OCR without any manual checking, but I thought SE would allow it.
windows 7 command line problem with the % symbol
By sonic12345 in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 14:45 -
VOB2MPG command line problem
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Mar 2010, 13:58 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
Subtitle Line Up problem
By ihmcjacky in forum SubtitleReplies: 3Last Post: 1st Jun 2009, 06:23 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44
