I have a problem i can capture good quality with pal50 if i record with pal60 the screens change the whole time from collors explain:
http://www.youtube.com/watch?v=LB78wHWFx9s
I googled for several hours but nothing what helps I have an ION video2pc recorder.
And If i play battlefield 3 on pal50 why i have then problems like lag server he stops with shootings when I want to spray.
I use cyberlink powerdirection v8 if you know another programma which I can change the collors.
Thank you,
Tanklessgunit
EDIT: I use for output a scart which i can input or output i found this one in a box he might be very old is this maybe the reason?
Results 1 to 9 of 9
OK. You need to explain yourself better.
Is this game PAL or NTSC ?. If it is PAL then you capture as PAL50.
Only if the game is NTSC should you attempt to capture as PAL60. This is a special format to convert NTSC to PAL by just altering the color. Do NOT use this mode for PAL sources. -
My game is PAL If i cap games with pal50 its a nice quality but most of the games you only can play with pal60 and if i capture it threw NTSC_433 Its altering the colors yeah, I played battlefield 3 with pal50 and its just laging can't spray stops with shooting like a lag server but connection was good. Is there anohter way? There is an option PAL_B if I use that option its just a blackscreen, Sound is recording and I hear it.
You need a capture device that supports PAL60 properly. PAL60 uses NTSC timing with PAL chroma encoding. Few capture devices support PAL60.
do you know which capture device can capture pal60 dont need roxio its to expensive just for making fun montages
As jagabo mentioned, few capture devices support PAL60. No probs with Roxio as I do not think it would work anyway.
The ones I have read about are:
Easycap DC60+ (the DC60+ bit is important as there are many versions of Easycap). Even then there are still many fakes of this. They are cheap but you pays your money and takes your choice. Even then, the device may not install right as it has many issues with drivers etc.
The genuine article is called Ezcap 116. But if you do not want to pay for a Roxio you will not want to pay £30($40-$50) for this either.
There are also some even higher price units. -
You are welcome to search the forums. We have old threads that do mention such capture devices by name, but as I live in NTSC land I do not remember what they are as I don't use them. Search for Pal60 and maybe add capture devices to that to have a good chance of finding the right old threads.
The Hauppauge USB Live 2 is a another USB device that can capture PAL60 in standard definition. When using the manufacturer-provided capture software, WinTV 7, one can edit a .ini to make PAL60 the default video standard for capture. http://www.hauppauge.co.uk/forum/showthread.php?22744-capture-Pal60-format. I expect it is possible to use the Hauppauge USB Live 2 to capture PAL60 with other programs too, if they allow full access to the driver feature that sets the video standard.
Capturing Pal60 With Easycap DC60
By e0turnerl in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2009, 11:07 -
capturing xbox pal60 avertv hybrid + fm volar usb A828
By ankmorph in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2009, 06:24 -
Capture problems, PAL60 option
By CoronaStar in forum Capturing and VCRReplies: 1Last Post: 11th Oct 2008, 07:38 -
Need a CC with PAL60 capability for the UK
By usernameinvalid in forum Capturing and VCRReplies: 21Last Post: 10th Oct 2008, 18:15 -
Help with packard bell ehr2080 dvd hdd recorder and pal60
By rickstain in forum DVD & Blu-ray RecordersReplies: 3Last Post: 31st Jan 2008, 02:59
