RGB vs YUY2
When you use vdub filters, most will require conversion to RGB colorspace when using "full processing mode"
If you are using avisynth filters, not vdub filters - most will allow you to stay in the same colorspace, and you can use video=>fast recompress instead of "full processing mode"
Splitting a file larger than 8gb for xbox 360 (HELP!!)
By Cornholio77 in forum Video ConversionReplies: 2Last Post: 2nd Oct 2012, 18:50 -
Problem with audio in file processed by GOTSENT
By Bavafan in forum AudioReplies: 3Last Post: 10th Sep 2010, 14:20 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
Better to save processed vid to a different h/d than original file?
By brassplyer in forum EditingReplies: 4Last Post: 6th Jan 2009, 05:07 -
Larger File Type
By AudioSync in forum Newbie / General discussionsReplies: 3Last Post: 18th Mar 2008, 12:20
