Results 1 to 13 of 13
  1. So have been trying how to feed image files to x264 built that I always use. I don't like syntax of Handbrake & or ffmpeg so plz don't recommend them.
    Have searched this forum but guides aarent available for x264 image sequence » movie
    Plz help
    My code so far...i know the input command needs work
    x264.exe --frames 1 --8x8dct --trellis 2 --subme 9 --psy-rd 1.5:0.5 --aq-strength 1.2 --input-res 3456x2304 --deblock -2:-2 -o "D:\Dad.mkv" "d:\Trainers\Dad\*.jpg"
  2. "d:\Trainers\Dad\*.jpg" will probalby not work,...
    you probably need to use something like: "d:\Trainers\Dad\%04d.jpg" if your files are named
  3. Originally Posted by Selur View Post
    This willnt work either, I thus used AVSscript as follows:
    source = ImageSource("c:\ff\%03d.jpg",fps=0.2)
    source = source.BilinearResize(1280,720)
    source = source.ConvertToRGB()
    return source
    ...& then fed it to x264 like:
    x264.exe --input-csp  yuv420p -o "D:\output.mkv" "d:\Program Files\AviSynth 2.5\Examples\input.avs"
    But the output mkv is extremely poor, don't know why
  4. Since you didn't specify a CRF value you got the default, CRF=23. Try specifying a lower CRF.
    I've never used the --input-csp argument but your AviSynth script is returning RGB and you are specifying --input-csp yuv420p. I don't know if that would cause problems. Change the ConvertToRGB() to ConvertToYV12() in your script.
    I don't know what you're converting but keep in mind that YV12 maintains chroma (colors) at half the resolution of the luma (greyscale). So small colored object (especially text) on colored backgrounds can get very blurry.
  5. Also your color spaces do not match,...
    Due to ConvertToRGB(), Avisynth return 4:4:4, but you tell x264 that the input-csp is 4:2:0.
    -> with mismatching color spaces output is bound to look strange,..
  6. Thnx for assisting someone who is trying to learn via experimenting. I mended my scriots as follows
    x264:
    x264.exe --crf 23 -o "D:\crf18.mkv" "d:\Program Files\AviSynth 2.5\Examples\imageseq.avs" 2>&1 | mtee /d/c/t log.txt
    pause
    avs:
    source = source.ConvertToYV12()
    return source
    the output log is:
    2012-10-26 15:55:57.752 avs [info]: 1280x720p 0:0 @ 3355443/16777216 fps (cfr)
    2012-10-26 15:55:57.752 avs [info]: color matrix: undef
    2012-10-26 15:55:57.752 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64
    2012-10-26 15:55:57.752 x264 [info]: profile High, level 3.1
    2012-10-26 15:55:57.752 [0.1%] 1/1001 frames, 0.38 fps, 159.53 kb/s, eta 0:43:41
    [0.2%] 2/1001 frames, 0.69 fps, 140.48 kb/s, eta 0:24:00
    [0.4%] 4/1001 frames, 1.26 fps, 130.10 kb/s, eta 0:13:14
    [0.5%] 5/1001 frames, 1.42 fps, 128.15 kb/s, eta 0:11:41
    [0.7%] 7/1001 frames, 1.81 fps, 123.87 kb/s, eta 0:09:09
    [0.8%] 8/1001 frames, 1.93 fps, 123.95 kb/s, eta 0:08:34
    [0.9%] 9/1001 frames, 2.02 fps, 127.21 kb/s, eta 0:08:10
    [1.1%] 11/1001 frames, 2.30 fps, 122.68 kb/s, eta 0:07:10
    [1.3%] 13/1001 frames, 2.56 fps, 117.37 kb/s, eta 0:06:25
    [2.1%] 21/1001 frames, 3.94 fps, 72.68 kb/s, eta 0:04:08
    [2.8%] 28/1001 frames, 4.99 fps, 54.53 kb/s, eta 0:03:14
    [3.5%] 35/1001 frames, 5.97 fps, 43.63 kb/s, eta 0:02:41
    [4.2%] 42/1001 frames, 6.84 fps, 36.37 kb/s, eta 0:02:20
    [4.9%] 49/1001 frames, 7.64 fps, 31.19 kb/s, eta 0:02:04
    [5.6%] 56/1001 frames, 8.37 fps, 27.29 kb/s, eta 0:01:52
    [6.3%] 63/1001 frames, 9.08 fps, 24.27 kb/s, eta 0:01:43
    [7.0%] 70/1001 frames, 9.73 fps, 21.85 kb/s, eta 0:01:35
    [7.7%] 77/1001 frames, 10.33 fps, 19.87 kb/s, eta 0:01:29
    [8.4%] 84/1001 frames, 10.88 fps, 18.22 kb/s, eta 0:01:24
    [9.2%] 92/1001 frames, 11.49 fps, 16.64 kb/s, eta 0:01:19
    [9.9%] 99/1001 frames, 11.98 fps, 15.47 kb/s, eta 0:01:15
    [10.6%] 106/1001 frames, 12.42 fps, 14.45 kb/s, eta 0:01:12
    [11.3%] 113/1001 frames, 12.84 fps, 13.56 kb/s, eta 0:01:09
    [12.1%] 121/1001 frames, 13.32 fps, 12.67 kb/s, eta 0:01:06
    [12.8%] 128/1001 frames, 13.69 fps, 11.98 kb/s, eta 0:01:03
    [13.5%] 135/1001 frames, 14.04 fps, 11.36 kb/s, eta 0:01:01
    [14.2%] 142/1001 frames, 14.37 fps, 10.80 kb/s, eta 0:00:59
    [14.9%] 149/1001 frames, 14.68 fps, 10.30 kb/s, eta 0:00:58
    [15.6%] 156/1001 frames, 14.97 fps, 9.84 kb/s, eta 0:00:56
    [16.3%] 163/1001 frames, 15.24 fps, 9.42 kb/s, eta 0:00:54
    [17.0%] 170/1001 frames, 15.49 fps, 9.03 kb/s, eta 0:00:53
    [17.7%] 177/1001 frames, 15.77 fps, 8.68 kb/s, eta 0:00:52
    [18.4%] 184/1001 frames, 16.01 fps, 8.35 kb/s, eta 0:00:51
    [19.1%] 191/1001 frames, 16.23 fps, 8.05 kb/s, eta 0:00:49
    [19.8%] 198/1001 frames, 16.46 fps, 7.76 kb/s, eta 0:00:48
    [20.5%] 205/1001 frames, 16.69 fps, 7.50 kb/s, eta 0:00:47
    [21.2%] 212/1001 frames, 16.90 fps, 7.26 kb/s, eta 0:00:46
    [21.9%] 219/1001 frames, 17.09 fps, 7.03 kb/s, eta 0:00:45
    [22.6%] 226/1001 frames, 17.30 fps, 6.81 kb/s, eta 0:00:44
    [23.3%] 233/1001 frames, 17.50 fps, 6.61 kb/s, eta 0:00:43
    [24.0%] 240/1001 frames, 17.68 fps, 6.42 kb/s, eta 0:00:43
    [24.7%] 247/1001 frames, 17.85 fps, 6.24 kb/s, eta 0:00:42
    [25.4%] 254/1001 frames, 18.02 fps, 6.07 kb/s, eta 0:00:41
    [26.1%] 261/1001 frames, 18.19 fps, 5.91 kb/s, eta 0:00:40
    [26.8%] 268/1001 frames, 18.34 fps, 5.75 kb/s, eta 0:00:39
    [27.5%] 275/1001 frames, 18.46 fps, 5.61 kb/s, eta 0:00:39
    [28.2%] 282/1001 frames, 18.62 fps, 5.47 kb/s, eta 0:00:38
    [28.9%] 289/1001 frames, 18.76 fps, 5.34 kb/s, eta 0:00:37
    [29.6%] 296/1001 frames, 18.87 fps, 5.22 kb/s, eta 0:00:37
    [30.4%] 304/1001 frames, 19.03 fps, 5.08 kb/s, eta 0:00:36
    [31.1%] 311/1001 frames, 19.15 fps, 4.97 kb/s, eta 0:00:36
    [31.8%] 318/1001 frames, 19.28 fps, 4.86 kb/s, eta 0:00:35
    [32.4%] 324/1001 frames, 19.34 fps, 4.77 kb/s, eta 0:00:35
    [33.1%] 331/1001 frames, 19.46 fps, 4.67 kb/s, eta 0:00:34
    [33.8%] 338/1001 frames, 19.56 fps, 4.58 kb/s, eta 0:00:33
    [34.5%] 345/1001 frames, 19.66 fps, 4.48 kb/s, eta 0:00:33
    [35.1%] 351/1001 frames, 19.72 fps, 4.41 kb/s, eta 0:00:32
    [35.9%] 359/1001 frames, 19.86 fps, 4.31 kb/s, eta 0:00:32
    [36.6%] 366/1001 frames, 19.96 fps, 4.23 kb/s, eta 0:00:31
    [37.3%] 373/1001 frames, 20.07 fps, 4.15 kb/s, eta 0:00:31
    [38.0%] 380/1001 frames, 20.14 fps, 4.08 kb/s, eta 0:00:30
    [38.7%] 387/1001 frames, 20.24 fps, 4.00 kb/s, eta 0:00:30
    [39.4%] 394/1001 frames, 20.33 fps, 3.93 kb/s, eta 0:00:29
    [40.1%] 401/1001 frames, 20.40 fps, 3.87 kb/s, eta 0:00:29
    [40.8%] 408/1001 frames, 20.48 fps, 3.80 kb/s, eta 0:00:28
    [41.5%] 415/1001 frames, 20.55 fps, 3.74 kb/s, eta 0:00:28
    [42.2%] 422/1001 frames, 20.64 fps, 3.68 kb/s, eta 0:00:28
    [42.9%] 429/1001 frames, 20.71 fps, 3.62 kb/s, eta 0:00:27
    [43.7%] 437/1001 frames, 20.82 fps, 3.55 kb/s, eta 0:00:27
    [44.4%] 444/1001 frames, 20.87 fps, 3.50 kb/s, eta 0:00:26
    [45.2%] 452/1001 frames, 20.96 fps, 3.44 kb/s, eta 0:00:26
    [45.9%] 459/1001 frames, 21.04 fps, 3.39 kb/s, eta 0:00:25
    [46.6%] 466/1001 frames, 21.11 fps, 3.34 kb/s, eta 0:00:25
    [47.3%] 473/1001 frames, 21.19 fps, 3.29 kb/s, eta 0:00:24
    [48.0%] 480/1001 frames, 21.25 fps, 3.24 kb/s, eta 0:00:24
    [48.7%] 487/1001 frames, 21.29 fps, 3.19 kb/s, eta 0:00:24
    [49.4%] 494/1001 frames, 21.35 fps, 3.15 kb/s, eta 0:00:23
    [50.0%] 501/1001 frames, 21.42 fps, 3.11 kb/s, eta 0:00:23
    [50.7%] 508/1001 frames, 21.49 fps, 3.07 kb/s, eta 0:00:22
    [51.4%] 515/1001 frames, 21.53 fps, 3.02 kb/s, eta 0:00:22
    [52.1%] 522/1001 frames, 21.59 fps, 2.98 kb/s, eta 0:00:22
    [52.8%] 529/1001 frames, 21.65 fps, 2.95 kb/s, eta 0:00:21
    [53.5%] 536/1001 frames, 21.70 fps, 2.91 kb/s, eta 0:00:21
    [54.3%] 544/1001 frames, 21.77 fps, 2.87 kb/s, eta 0:00:20
    [55.0%] 551/1001 frames, 21.82 fps, 2.83 kb/s, eta 0:00:20
    [55.7%] 558/1001 frames, 21.88 fps, 2.80 kb/s, eta 0:00:20
    [56.4%] 565/1001 frames, 21.93 fps, 2.76 kb/s, eta 0:00:19
    [57.1%] 572/1001 frames, 21.99 fps, 2.73 kb/s, eta 0:00:19
    [57.8%] 579/1001 frames, 22.03 fps, 2.70 kb/s, eta 0:00:19
    [58.5%] 586/1001 frames, 22.09 fps, 2.67 kb/s, eta 0:00:18
    [59.2%] 593/1001 frames, 22.13 fps, 2.64 kb/s, eta 0:00:18
    [59.9%] 600/1001 frames, 22.18 fps, 2.61 kb/s, eta 0:00:18
    [60.7%] 608/1001 frames, 22.25 fps, 2.57 kb/s, eta 0:00:17
    [61.4%] 615/1001 frames, 22.29 fps, 2.54 kb/s, eta 0:00:17
    [62.0%] 621/1001 frames, 22.31 fps, 2.52 kb/s, eta 0:00:17
    [62.7%] 628/1001 frames, 22.34 fps, 2.49 kb/s, eta 0:00:16
    [63.4%] 635/1001 frames, 22.38 fps, 2.46 kb/s, eta 0:00:16
    [64.1%] 642/1001 frames, 22.42 fps, 2.44 kb/s, eta 0:00:16
    [64.8%] 649/1001 frames, 22.45 fps, 2.41 kb/s, eta 0:00:15
    [65.5%] 656/1001 frames, 22.49 fps, 2.39 kb/s, eta 0:00:15
    [66.2%] 663/1001 frames, 22.52 fps, 2.36 kb/s, eta 0:00:15
    [66.9%] 670/1001 frames, 22.55 fps, 2.34 kb/s, eta 0:00:14
    [67.6%] 677/1001 frames, 22.58 fps, 2.32 kb/s, eta 0:00:14
    [68.3%] 684/1001 frames, 22.62 fps, 2.29 kb/s, eta 0:00:14
    [69.0%] 691/1001 frames, 22.65 fps, 2.27 kb/s, eta 0:00:13
    [69.7%] 698/1001 frames, 22.68 fps, 2.25 kb/s, eta 0:00:13
    [70.4%] 705/1001 frames, 22.72 fps, 2.23 kb/s, eta 0:00:13
    [71.2%] 713/1001 frames, 22.77 fps, 2.20 kb/s, eta 0:00:12
    [71.9%] 720/1001 frames, 22.81 fps, 2.18 kb/s, eta 0:00:12
    [72.6%] 727/1001 frames, 22.83 fps, 2.16 kb/s, eta 0:00:12
    [73.3%] 734/1001 frames, 22.87 fps, 2.14 kb/s, eta 0:00:11
    [74.0%] 741/1001 frames, 22.89 fps, 2.12 kb/s, eta 0:00:11
    [74.7%] 748/1001 frames, 22.92 fps, 2.10 kb/s, eta 0:00:11
    [75.4%] 755/1001 frames, 22.94 fps, 2.08 kb/s, eta 0:00:10
    [76.1%] 762/1001 frames, 22.97 fps, 2.06 kb/s, eta 0:00:10
    [76.8%] 769/1001 frames, 22.99 fps, 2.05 kb/s, eta 0:00:10
    [77.5%] 776/1001 frames, 23.01 fps, 2.03 kb/s, eta 0:00:09
    [78.2%] 783/1001 frames, 23.03 fps, 2.01 kb/s, eta 0:00:09
    [79.0%] 791/1001 frames, 23.07 fps, 1.99 kb/s, eta 0:00:09
    [79.8%] 799/1001 frames, 23.12 fps, 1.97 kb/s, eta 0:00:08
    [80.5%] 806/1001 frames, 23.13 fps, 1.96 kb/s, eta 0:00:08
    [81.2%] 813/1001 frames, 23.16 fps, 1.94 kb/s, eta 0:00:08
    [81.9%] 820/1001 frames, 23.19 fps, 1.92 kb/s, eta 0:00:07
    [82.7%] 828/1001 frames, 23.23 fps, 1.91 kb/s, eta 0:00:07
    [83.4%] 835/1001 frames, 23.25 fps, 1.89 kb/s, eta 0:00:07
    [84.1%] 842/1001 frames, 23.28 fps, 1.87 kb/s, eta 0:00:06
    [84.8%] 849/1001 frames, 23.30 fps, 1.86 kb/s, eta 0:00:06
    [85.5%] 856/1001 frames, 23.33 fps, 1.84 kb/s, eta 0:00:06
    [86.2%] 863/1001 frames, 23.34 fps, 1.83 kb/s, eta 0:00:05
    [86.9%] 870/1001 frames, 23.37 fps, 1.82 kb/s, eta 0:00:05
    [87.6%] 877/1001 frames, 23.39 fps, 1.80 kb/s, eta 0:00:05
    [88.3%] 884/1001 frames, 23.41 fps, 1.79 kb/s, eta 0:00:04
    [89.0%] 891/1001 frames, 23.42 fps, 1.77 kb/s, eta 0:00:04
    [89.8%] 899/1001 frames, 23.45 fps, 1.76 kb/s, eta 0:00:04
    [90.6%] 907/1001 frames, 23.48 fps, 1.74 kb/s, eta 0:00:04
    [91.3%] 914/1001 frames, 23.50 fps, 1.73 kb/s, eta 0:00:03
    [92.0%] 921/1001 frames, 23.52 fps, 1.72 kb/s, eta 0:00:03
    [92.7%] 928/1001 frames, 23.54 fps, 1.71 kb/s, eta 0:00:03
    [93.4%] 935/1001 frames, 23.57 fps, 1.69 kb/s, eta 0:00:02
    [94.1%] 942/1001 frames, 23.58 fps, 1.68 kb/s, eta 0:00:02
    [94.8%] 949/1001 frames, 23.60 fps, 1.67 kb/s, eta 0:00:02
    [95.8%] 959/1001 frames, 23.68 fps, 1.65 kb/s, eta 0:00:01
    [100.0%] 1001/1001 frames, 24.57 fps, 1.59 kb/s, eta 0:00:00
    x264 [info]: frame I:5     Avg QP: 3.02  size: 19963
    2012-10-26 15:56:35.984 x264 [info]: frame P:260   Avg QP:16.91  size:  3326
    2012-10-26 15:56:35.984 x264 [info]: frame B:736   Avg QP:17.00  size:    37
    2012-10-26 15:56:35.984 x264 [info]: consecutive B-frames:  1.9%  0.2%  0.0% 97.9%
    2012-10-26 15:56:35.984 x264 [info]: mb I  I16..4: 80.7% 15.8%  3.5%
    2012-10-26 15:56:35.984 x264 [info]: mb P  I16..4:  0.6%  3.2%  0.7%  P16..4:  0.0%  0.0%  0.0%  0.0%  0.0%    skip:95.4%
    2012-10-26 15:56:35.984 x264 [info]: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%  L0: 0.0% L1:100.0% BI: 0.0%
    2012-10-26 15:56:35.984 x264 [info]: 8x8 transform intra:54.5% inter:83.0%
    2012-10-26 15:56:35.984 x264 [info]: coded y,uvDC,uvAC intra: 62.0% 51.8% 43.9% inter: 0.0% 0.0% 0.0%
    2012-10-26 15:56:35.984 x264 [info]: i16 v,h,dc,p: 91%  1%  3%  5%
    2012-10-26 15:56:35.984 x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 18% 14%  5%  8%  9%  8%  9%  9%
    2012-10-26 15:56:35.984 x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 19%  8%  5% 12%  9%  9%  6%  5%
    2012-10-26 15:56:35.984 x264 [info]: i8c dc,h,v,p: 70% 14% 10%  6%
    2012-10-26 15:56:35.984 x264 [info]: Weighted P-Frames: Y:0.8% UV:0.8%
    2012-10-26 15:56:35.984 x264 [info]: ref P L0: 70.1% 14.8% 12.1%  2.4%  0.6%
    2012-10-26 15:56:35.988 x264 [info]: kb/s:1.59
    2012-10-26 15:56:35.988 encoded 1001 frames, 24.57 fps, 1.59 kb/s
    Picture info that I want to encode:
    Resolution Unit: 0File Size: 138197 bytesFile DateTime: 26-Oct-2012 04:07:07Height: 900Width: 1440IsColor: 1Process: 192Resolution: 1440x900Color: ColorJpeg Process: Baseline
    Info of output video:
    General
    Complete name                  : D:\crf18.mkv
    Format                         : Matroska
    Format version                 : Version 2
    File size                      : 986 KiB
    Duration                       : 1h 23mn
    Overall bit rate               : 1 614 bps
    Writing application            : x264 r2200+677M 3a754e7
    Writing library                : Haali Matroska Writer b0
    Video
    Format                         : AVC
    Format/Info                    : Advanced Video Codec
    Format profile                 : High@L3.1
    Format settings, CABAC         : Yes
    Format settings, ReFrames      : 4 frames
    Codec ID                       : V_MPEG4/ISO/AVC
    Duration                       : 1h 23mn
    Width                          : 1 280 pixels
    Height                         : 720 pixels
    Display aspect ratio           : 16:9
    Frame rate                     : 0.200 fps
    Color space                    : YUV
    Chroma subsampling             : 4:2:0
    Bit depth                      : 8 bits
    Scan type                      : Progressive
    Writing library                : x264 core 125 r2200+677M 3a754e7
    Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0000 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language                       : English
    Now the real problem is when I open the output video file in any player it states the duration of file is 1hr23min? Strange because there are a total of 12 jpg files that am encoding & with a fps=0.2 it means each picture duration is 5sec & we will get a total movie having duration of 12x5=60sec=1min
  7. since x264 outputs "encoded 1001 frames" which @0.2 fps results to 1:23min the problem lies with your avisynth script, which seems to output 1001 frames
    Not sure if ImageSource even supports fps < 1,..
    -> check your avisynth scrip with Virtual Dub or similiar to see how many frames it returns,..
  8. Originally Posted by Selur View Post
    Respected sir, I am just a chemical engineer who is trying to learn video encode for personal reasons.
    Now because I have displayed everything there is no room for error in any script! I have dopne some maths & discovered that
    Duration x fps = totalFrames
    Now am adding 12 pics & previous posts states that with a fps=0.2 i must get 60sec movie thus
    60sec x 0.2frames/sec = 12
    Thus we only have to encode 12 frames. Without changing any other script I just changed x264cli & got perfect result:
    x264.exe --crf 23 --frames 12 -o "D:\crf18.mkv" "d:\Program Files\AviSynth 2.5\Examples\imageseq.avs" 2>&1 | mtee /d/c/t log.txt
  9. ImageSource() defaults to 1001 frames. You have to specify the start and end frame numbers if you want something different. ImageSource("c:\ff\%03d.jpg", start=0, end=11, fps=0.2)
  10. @jagabo
    can you also explain this bit of log:
    resize [warning]: converting from bgr24 to yuv420p
  11. Originally Posted by ioncube View Post
    This means you convert from RGB colorspace to Y'CbCr and subsample the chroma to 4:2:0
    http://en.wikipedia.org/wiki/Chroma_subsampling
    http://en.wikipedia.org/wiki/Chroma_subsampling#4:2:0
  12. I have screenshots of resolution 1440x900 which I resize via BilinearResize(1280,720) which gives the above mentioned error. Can you tell me how do I find the colorspace of my picture & get rid of this error
  13. I've never seen BilinearResize() give that warning but you should be able to avoid it by converting to YV12 before resizing.
    You can use Info() anywhere in your script to see information about the video at that point in the script. The information will be written onto the image.
