If I double click on an audio file in a folder it is added to the existing potplayer playlist but not played immediately.
How can I let potplayer play immediate the added file?
Preferences, General tab, Multiple Launching. Try the "Play the Clicked file" option, not "Add clicked file to the playlist"
Thanks for writing.
It doesn't work.
Yes the clicked file is immediately played but the other files in the playlist are removed. -
About the only way to play a file immediately and still keep the playlist is change the above option to Launch multiple players and close the immediate one when you are done with it. Other than that, drag it to the playlist and double click to play immediately. I assume you are playing a song to see if you wish to add it to your playlist? If so, add any you thing you might like and double click to play then right click and remove if you do not wish to keep it.
PotPlayer settings
By Montmorency in forum Newbie / General discussionsReplies: 12Last Post: 1st Nov 2014, 02:04 -
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2014, 23:23 -
PotPlayer/DirectX
By jdvideo in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2012, 18:18 -
About PotPlayer
By minegroasprilla in forum Software PlayingReplies: 3Last Post: 3rd Jun 2012, 12:01 -
Customizing PotPlayer
By positcert in forum Software PlayingReplies: 0Last Post: 13th Sep 2011, 18:57
