Hey,
Are hardware encoders the best way to go for quality? Also what about the speed?
Could someone recommend one?
Thankx
For speed- Hardware.
For quality - Software.
If you are going to buy a hardware encoder, be sure to see some mpeg samples from the manufacturer, before you buy.
I personally capture to AVI and then compress to mpeg.
You can do more, like apply filters, etc. to a capture.
Takes longer, but the final result is not matched by any hardware encoder.
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
They certainly are faster than software encoders (as you would expect), and consider that the folks who encode MPEG-2 for retail DVDs use hardware encoders. It might help to give a "not-to-exceed price" to narrow down the recommendations, unless you are on an unlimited budget, otherwise you'll get all kinds of suggestions, from cheap things that aren't true hardware encoders all the way to turnkey systems in the mid-5-figure range.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Getting started, Hardware recommendations?
By MrHawhn in forum Newbie / General discussionsReplies: 18Last Post: 17th May 2011, 23:19 -
Recommendations on HTPC Hardware or post yours!
By rxloren in forum Newbie / General discussionsReplies: 2Last Post: 4th Nov 2010, 14:36 -
Hardware MPEG 4 Encoders: Worthwhile?
By darkarn in forum Capturing and VCRReplies: 6Last Post: 29th Jul 2010, 20:16 -
encoders?
By just in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2008, 10:15 -
Capture 8mm/VHS > DV, recommendations for hardware
By nutshellml in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2008, 22:07
