I ripped my uncles dvd then converted to avi so I could use Windows Movie Maker to do some editing and then converted back to dvd but the resulting dvd is all pixelated - the quality is very poor - far removed from the original... Any suggestions?
Results 1 to 10 of 10
How did you convert back to DVD?
I would convert to dv-avi with windows movie maker and then convert to a dvd with for example avstodvd. -
what kind of editing? if it's simple cuts you could keep it in the original mpeg-2 the whole way and not lose anything by re-rendering.
Several reconversions cause pixelations. Especially if you are converting to wmv with low bitrate using windows movie maker. Instead try convert to high bitrate wmv or dv-avi with movie maker and then use convertxtodvd.
And if you are just doing cuts can you use dvd shrink to edit and reauthor your dvd with no quality loss. Like aedipuss mentions. -
So if I try to convert with a higher bitrate would that improve the quality?
The best way to keep the original quality is not to convert at all. DVDShrink has already been mentioned if all you want to do is cut. Also, there are some very good commercial programs that will reencode only where you make edits and return the rest unchanged. Check out VideoRedo and/or MPEG Video Wizard DVD.
But you've already been asked twice what kind of work you want to perform and haven't answered yet. So who really knows? The way you're doing it now though (and you haven't even made that clear) isn't optimum. -
I want to try and sharpen some sections, lighten other sections and cut some sections and include title pages and insert from footage from another clip.
Oh, this is much more than just editing and will require a full reencode afterwards. I do these kinds of things using AviSynth. I didn't know Windows Movie Maker even had the ability to do all the things you mentioned. If it does, I'd second Baldrick's earlier suggestion to first convert to DV AVI before making the changes. Save it out as another DV AVI if possible, and then use Avs2DVD on it to convert it back to DVD.
Pixelation during playback
By Port in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Aug 2011, 15:01 -
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 13:52 -
Pixelation Problem
By Renta in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 22:46 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 02:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 00:40
