Will the PS3 play MP4 out of the box or does it require me to download drivers online? And will it allow me to transfer videos from USB drive to PS3 HDD?
In both cases answer is yes however beware Cinavia, some codec limitations etc.
https://en.wikipedia.org/wiki/PlayStation_3_system_software#Compatible_media_formats -
Depends ... this from playstation.net
The following is provided for those asking the same question repeatedly
Types of files that can be played
The following types of files can be played under (Video).
Memory Stick Video Format
- MPEG-4 SP (AAC LC)
- H.264/MPEG-4 AVC High Profile (AAC LC)
- MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
MP4 file format
MPEG-1 (MPEG Audio Layer 2)
MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
MPEG-2 TS(MPEG2 Audio Layer 2, AC3(Dolby Digital), AAC LC)
AVI
- Motion JPEG (Linear PCM)
- Motion JPEG (μ-Law)
AVCHD (.m2ts / .mts)
DivX
WMV
- VC-1(WMA Standard V2)
Hints
Depending on the data type, some files may not be playable or some control panel options may not function during playback.
Some video files distributed over the Internet have playback restrictions.
For details, contact the content provider.
To play WMV format files, you must go to (Settings) > (System Settings) and set [Enable WMA Playback].
When using a USB adaptor to play video files, you may need to use a USB adaptor (not included) that supports copyright-protection features (to play copyright-protected files).
When using a USB adaptor to play AVCHD-format video files saved on Memory Stick™ media, use a device that supports Hi-Speed USB (USB 2.0).
WMV format copyright-protected files cannot be played.
Maybe add a link to this info or sticky it ... were getting quite a few asking this same question lately.
Q: What if my file wont play ?
A: Use mediainfo to determine the internal codecs used on problem file .... if it fails to match that as stated above you do the following.
1: Convert
2: Stream video from pc to ps3
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 11:53 -
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22 -
How can I play mp4 files with subtitles on PS3?
By furtem in forum SubtitleReplies: 8Last Post: 24th Jan 2010, 15:03 -
How to edit mp4 files and play them on my PS3?
By FlipUser in forum Video ConversionReplies: 3Last Post: 21st Oct 2009, 18:25 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 22:24
