I have this timeline which I am exporting from Adobe Premiere. The format is PAL DV.
I then have to put this footage into Final Cut (Express) and re-export it as a MOV file (there is a good reason for this). This format is also PAL DV (MOV)
Anyway, my question is: will I lose any quality in the "conversion" ?
	Not if you just import and export and nothing else . It's lossless re-wrapping of the container (Final Cut can smart render DV).
 If you do other things you might lose quality
 There are other ways to re-wrap as well - why are you using Final Cut ? You can export PAL DV MOV from Premiere , or re-wrap using other utilities as well
  How to reduce filesize and to not lose too much quality?By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48
  HOw come .iso files lose qualityBy ninjinturdle in forum DVD RippingReplies: 2Last Post: 8th Dec 2010, 09:52
  Increase the bitrate---> Lose Quality?By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36
  i need help to remaster my old vhs tapes to dvd quality(for mac or windows)By ultimate15red in forum EditingReplies: 2Last Post: 12th Nov 2009, 07:13
  Every Time I Crop, I Lose Quality!By terminalh in forum Video ConversionReplies: 8Last Post: 18th Jan 2009, 14:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
