I was hoping someone could clarify and give me some info regarding certain audio types working on xbox 360. I used to think that no audio format containing 6 channel audio wold work on xbox 360 but i have some files that are. Can someone explain why some work? Is 6 channel audio different than 5.1 audio? And could someone tell me what 6 channel audio formats do not work on xbox?
MediaInfo on file that is working with 6 channel audio on xbox 360
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 25mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 236 MiB (17%)
Alignment : Aligned on interleaves
Interleave, duration : 32 ms (0.80 video frame)
Getting 5.1 (or 6 channel) audio on the Xbox 360 depends on how you use it.
If you are streaming from WMP or a similar kind of server, or if you are playing video from a USB device or a data disc, then your options for 5.1 audio are either AC3 in an AVI container or WMA Pro in a WMV container.
If you set up your Xbox as a Windows Media Center Extender with Windows 7 (and maybe even 8), then you have more options. avc/ac3 .M2TS and mpeg2/ac3 .MPG files seem to work OK, and I suspect that even avc/aac 5.1 .MP4/MOV files might work, though I haven't tested any. -
ok so as cornucopia was saying, if i see a 6 channel file with LFE in the mediainfo will it also work on the xbox (via vuze thats what i am using) even if its AAC as well or only AC3 via USB or vuze??
Not sure if vuze gives the same flexibility as Windows Media Center, as you were saying some avc/ac3 etc. seem to play via streaming to xbox. Maybe Vuze will do the same? Its very flexibleLast edited by Cornholio77; 21st Oct 2012 at 22:30.
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
How do I hook external audio up to my ps2/xbox 360?
By hellfire45 in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2009, 23:37 -
HD on xbox 360 not working, probably audio issiue?
By sance in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2008, 08:05
