hi peeps, i really need some help i am now on my second acard duplicator i am using ritek dvd's however when i burn dvd's sometimes it seems like its not closing the disc, so it says it has copied 9 dvd's and you can see the burn mark but when you put them in a pc or dvd player they act like they are blank...
do you have any ideas.
Possibilities :
1) Bad first master DVD - check master DVD, check duplicator with different other master DVD (high)
2) Bad ritek DVD media - check with different DVD media (high)
3) Bad acard duplicator DVD Writers (low)
4) Bad acard duplicator controller (low)
5) No compatible dvd media with acard duplicator (high)Last edited by roma_turok; 21st Oct 2012 at 19:16.
ritek is usually rated bottom of the barrel piss poor media. most duplicators i've used only accept taiyo yuden professional grade blanks and i've never had a problem with one of them out of a duplicator.
acard dvd duplicator
By johnthedog in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Mar 2010, 13:08 -
By johnthedog in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2010, 15:43 -
DVD duplicator help?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 12th Sep 2009, 11:46 -
DVD duplicator question!
By slaak in forum Newbie / General discussionsReplies: 23Last Post: 24th Nov 2008, 20:36 -
Best writer in a duplicator
By Habby in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 04:00
